LS7 Oil Pressure Gauge/Lines
Old Mar 27, 2006 | 03:37 PM
pcf_mark's Avatar
Default LS7 Oil Pressure Gauge/Lines
How is anyone tapping into the LS7 for a mechanical oil pressure gauge? Or is there an electronic sender we can use to send to an aftermarket electronic gauge? Or where is the sender and can we yank it in favor of an Autometer?
Also which port is in and which is out in the pan for the dry sump with respect to the front of the engine?
Old Mar 27, 2006 | 05:15 PM
MSURacing's Avatar
I think UMI Racing has an adapter fitting that replaces your stock sensor. It has an 1/8" pipe fitting.
Old Mar 27, 2006 | 06:33 PM
John B's Avatar
Moderator
Use the boss right above the oil filter (where the C5/6) tap into the block).
Old Mar 27, 2006 | 06:45 PM
61LS7's Avatar
John, just t o be sure, you are saying to remove the small boss above the oil filter and drill and tap it for the mech guage - right? BTW, how did you make out with your clutch and flywheel - we talked when you ran into the pilot bearing issue. Larry
Old Mar 27, 2006 | 07:34 PM
pcf_mark's Avatar
Remove the small manifold looking device held on by to M6 screws and tap into it for a 1/8 npt? That is an odd looking part - anyone know what it does? Not very big for adding a connection. Where does the PCM pick it up at?
Can anyone confirm which is in and which is out on the pan for the dry sump lines?
Old Mar 28, 2006 | 09:17 PM
61LS7's Avatar
Mark, I have the same question you do. I will post a new entry and try again.
Old Mar 28, 2006 | 11:21 PM
John B's Avatar
Moderator
Perfect!
Yep!
You got it!
Rear is in, front is out.
