LS7 connecting rod
Old Apr 2, 2006 | 12:55 PM
Dune-LS1's Avatar
Default LS7 connecting rod
Who has had a good look at this rod? I'm thinking about getting a set and putting in some CARR bolts and using it in a quick revving Warhawk block 427. Couple those rods with a Magnum XL crank shaft and a set of light weight billet pistons....Hmmmm. Thoughts???
Old Apr 2, 2006 | 07:02 PM
leaftye's Avatar
How does the price compare with aftermarket Ti rods?
Old Apr 2, 2006 | 07:05 PM
Katech_Jason's Avatar
LS1TECH Sponsor
We are running 600-650hp with our rebushed LS7 rod with no problems. We have modified our LS1 rod bolt to fit the LS7 rod also. The factory bolts can only be torqued 3 times and they already get torqued twice at Wixom. We are still testing the bolt though.
Old Apr 2, 2006 | 07:26 PM
Dune-LS1's Avatar
You're probably looking a 3K for a set aftermarket vs. $700.00 for the factory piece.
Right now, I only use Carrillo <(great rod) but they are a little heavy. It would be nice if the factory rod with some CARR bolts would hold up to 800 HP... I'd like to try it but I don't want to wipe out a $4000.00 block just to find out.
Old Apr 2, 2006 | 07:27 PM
Dune-LS1's Avatar
What kind of rod bolt are you using?
Old Apr 2, 2006 | 07:38 PM
LS1TECH Sponsor
modified Katech bolt. Still testing though.
Old Apr 3, 2006 | 09:46 AM
427 LS1's Avatar
I have a set of LS7 Ti rods I'll sell you for $550 with very little dyno time on them, perfect condition. I also can get ARP 2000 bolts for a good upgrade. Let me know if you need them. Thanks Dave
Old Apr 4, 2006 | 01:55 PM
chad@xtreme's Avatar
We are putting a LS7 in a C5 with LPE TT kit. We are using ARP rod bolts. PT#xxxxxxxx
Chad
Old Apr 4, 2006 | 02:48 PM
madmaxz's Avatar
ls7 Ti rod part # 12586258 $78 at gmpartsdirect
What are the spec's? length/weight etc.
How about the LS7 crank part #12568820 can it be used in an ls1/lq9 iron 408?
Old Apr 4, 2006 | 03:22 PM
427 LS1's Avatar
Don't forget the shipping charges on gmpartsdirect. The Ti rods are really $766 a set shipped - $148 for shipping
LS7 crank is $814 shipped.
The crank has a longer snout for the dry sump setup, plus the crank pulley for the stock LS7 is for the Y body offset of coarse.
Old Apr 4, 2006 | 03:55 PM
NO-OPTION-2002's Avatar
Length = 6.067" as per the GM Performance Parts catalog.
Old Apr 4, 2006 | 05:05 PM
427 LS1's Avatar
Mine weigh 466 grams total with bolts.
Old Apr 8, 2006 | 01:37 PM
KCS's Avatar
KCS
Moderator
Isn't the reluctor wheel different?
Old Apr 8, 2006 | 01:45 PM
leaftye's Avatar
Different from what? We're talking about assembling a bottom end.
Old Apr 8, 2006 | 08:19 PM
gollum's Avatar
Aftermarket has always used a heavier and longer than stock rod with their stroker kits. But then GM throws everyone a curve with this lighter and SHORTER 6.064" 427 titanium rod. Hell this new rod is shorter than the 6.098" LS1 rod.
Would it be possible to have a set of custom 4.00" stroke 383 or 402 pistons made to fit the shorter 6.067 LS7 rod or maybe even the LS1 rod?
Old Apr 9, 2006 | 02:21 AM
stang90gt50's Avatar
even ff the LS7 crank snout is longer, you should still be able to bolt on a fbody balancer. Also with the different reluctor wheel, cant you just change some settings in HPtuners for the different reluctor wheel and just put the crank in a normal 6.0L/LS2 block using factory 6.0L/LS2 crank sensor? I would guess so.
Also on the rods, I just looked them up and they are $77 each. $616. If you call when you make the order they combine shipping (since it's charging you per rod) and wouldnt cost more than $25 for shipping. it would be definately worth buying some custom pistons (which would be no big deal) and have a nice little high rpm setup.
Old Apr 9, 2006 | 01:36 PM
KCS's Avatar
KCS
Moderator
Refer tp post #9 and #10.
Old Apr 11, 2006 | 12:24 AM
Dune-LS1's Avatar
Pistons would not be a problem. <(Go custom) It's a better way to go anyway... You can have a set of light weight pistons to match those light weight rods... Killer rev engine with a magnum XL crank and a aluminum flywheel <(For us stick guys that is)
Old Apr 11, 2006 | 02:50 AM
Bill Reid's Avatar
F-Body (or truck / SUV) balancer bolted to a crate LS7 crank with its longer snout will not line up with the accessories...
Old Apr 11, 2006 | 03:34 AM
KAOS's Avatar
so you can get a full titanium rod for 77 bucks, that sounds awful cheap. i thought these rods were way higher than this. so why buy something like compstar or any other big name, titanium is stronger and lighter than steel right?
