Who is the authority on custom cams ... ?
Old Apr 2, 2006 | 01:56 PM
x phantom x's Avatar
STF veteran / 10 second club
Default Who is the authority on custom cams ... ?
I'm looking to get a custom cam ground for my 402 LS2.
It's going to have ETP's - LS7 based heads, for a 4.00" bore.
Since these heads are far from an average head, I would like to have a custom cam ground for the motor, instead of using an off the shelf cam.
I'm looking for your opinions on what shop would make the best custom cam?
(I know this will be opinionated, but I really am just looking for a place to start my search).
Old Apr 2, 2006 | 02:37 PM
Nate_Taufer's Avatar
Thunder racing, Ed Curtis, A & A corvette, maybe Phil at pro-street motorsports.
Nate
Old Apr 2, 2006 | 04:23 PM
Beast96Z's Avatar
Nate
I'd agree with 2 of those 4 for a real "custom" cam. A&A and Phil are good guys, but I don't know about them being true camshaft designers. (Not meant to be deragatory towards either)
Old Apr 2, 2006 | 05:03 PM
DrkPhx's Avatar
There's Mike at Rapid Motorsports as well. He was one of the first to do cams for the LS2 402's.
Old Apr 2, 2006 | 08:07 PM
Yeah, I've seen some great results from them. I wasn't aware thunder did custom cams.
Old Apr 2, 2006 | 09:31 PM
gonbad's Avatar
Alan Futral at Futral Motorsports!
Old Apr 3, 2006 | 09:21 PM
I was thinking them, but when I was getting my original 402 setup going, I called them and they only really seemed to suggest off the shelf cams. I don't know whether it was because that was about a year ago and they had less experience or they didn't really do custom grinds.
Old Apr 3, 2006 | 10:31 PM
Dune-LS1's Avatar
I've been dealing with Comp Cams for over a MONTH and they aren't even close to having something I would run in my tow vehicle!
Old Apr 3, 2006 | 10:40 PM
JPMuscle's Avatar
Bret Bauer at Bauer Racing
-john
Old Apr 4, 2006 | 05:45 PM
Phil99vette's Avatar
7 Second Club
Does anyone really custom grind cams or do we just call a cam grinder and have the specs ground? We don't use custom lobes, they are all shelf lobes ground to our specs. I guess to find out the cam specs we would need to know....
1) Cylinder head flow numbers
2) Fuel
3) Compression ratio
4) Where you want to shift the car
5) Gears
6) Tranny
7) Intake
8) Exhaust choice
9) Goals for ET and MPH
And there is no "best" cam...
Old Apr 4, 2006 | 06:49 PM
ThirdGenLS1's Avatar
Geoff at thunder is coming up with a cam for me as we speek.
Old Apr 4, 2006 | 07:29 PM
2) Fuel
5) Gears
6) Tranny
7) Intake
8) Exhaust choice
Right. And I would assume ANYONE who was grinding a cam would have to be supplied with that info. Obviously you would give them the head flow specs, CR, where you want the redline to be, what gears you plan on running, Tranny is a no brainer, and intake/exhaust would be involved as well. I would have thought that would be standard info when designing a cam, not a huge amount of unobtainable information as you present it as being?
As for the "best" cam comment - of course there is a "best." The "best" cam would be the cam that best fits the customer's specifications of power, drivability, idle characteristics, etc. Obviously, the definition of Best would be based on personal opinion, which is why I said "this will be opinionated."
All my question was asking is Give Me a Starting point in my search ... suggestions as to what shops would be the best to speak to for designing a cam for my 402. I'm not asking the board members to design one for me, I will leave that to the pro's.
Old Apr 4, 2006 | 10:43 PM
7 Second Club
Hey I am with ya. Not sure why you think I implied the information was unobtainable.. When we did the cams for the ET 225 hyd roller and 240 solid roller, we used our cam software and 3 grinders and they all basically said the same thing withing a couple of degrees. I think we initally came up with a 252/254 - 260 and the 3 "Pro" grinders said 250/260 254/260 and 248/256. Good Luck
Why don't you just call ET Performance? They offer custom spec'd cams for their heads.
Old Apr 5, 2006 | 12:15 AM
MagikMan's Avatar
If you want to be fast man... talk to Cartek... give Dave a call... he's the man
Old Apr 5, 2006 | 01:01 AM
Ah my bad then, I guess I misread what you were saying ...
I plan on calling ETP, but I want at least 4-5 places to call, get some suggestions, etc. I went through 3 cams on my LS1, and this is now my second setup on the LS2 ... I'm honestly getting tired of changing it, so I want to get this one right. lol.
Old Apr 5, 2006 | 02:45 AM
jhong321's Avatar
You might want to give Rick a call at Synergy motorsports. He is very good at cam selection and has a local guy that will grind to his specs. I have seen him talk with people about there cam and he will go threw all there driving habits and make sure they get a good cam not just some big number dyno queen cam.
Old Apr 5, 2006 | 05:40 AM
Blktie8's Avatar
Default My Cam
I like the work Ed Curtis does.
He designs cams to your requirments ,and parts you're going to install.
ETP HEADS ,the choice heads
Old Apr 5, 2006 | 08:40 AM
7 Second Club
Its all good, why not post all of the information here. I'll take a stab @ the cam specs. My track record for fast LS1s may not be as long as W2W or a big LS1 company but you'll see more big things in the coming weeks. You are going to have better luck with someone who has a computer program and experience with the ET products.
Old Apr 5, 2006 | 09:10 AM
BigBronco's Avatar
2) Fuel
5) Gears
6) Tranny
7) Intake
8) Exhaust choice
thank god someone with a brainnnnnn
Shout at me as well Mike and I can get you helped out as well too
Old Apr 5, 2006 | 11:22 PM
v8pwr's Avatar
A shop I never see mentioned here is LSM Engineering , call them about a cam .
