Bone Stock ZO6 dyno numbers!!!
Old Apr 19, 2006 | 03:03 PM
383ss's Avatar
man those are just awesome numbers
Old Apr 19, 2006 | 03:14 PM
Turo's Avatar
Badass numbers! Just out of curiosity, anyone know what gas mileage those cars get stock? I bet its pretty decent even though its a 7.0L engine.
Old Apr 19, 2006 | 03:18 PM
Wesmanw02's Avatar
They are rated at 16/26, which is damn good fuel economy for a 7.0 making 500+HP, especially on the highway
Old Apr 19, 2006 | 07:37 PM
blackbird95's Avatar
Originally Posted by Stang's Bane
L-88's were rated at 430hp @5600 rpm. The actual output was actually closer to 560-580 @6400 rpm. It was said then you could put mufflers on theem and it would blow the cores out in just 2 weeks. L-88 was in the same tune as a ZL-1 just with an iron block.
Exactly I just wasn't sure what the actual numbers were so I just threw a couple out as an example. Thanks for the info though!
Old Apr 19, 2006 | 07:43 PM
SailorZ28's Avatar
Maybe in about 10 years I can buy a used C6 Z06....
Old Apr 19, 2006 | 08:20 PM
Redline-Motorsports's Avatar
Originally Posted by J-Rod
Good numbers. Keep an eye on IAT as that is what kills dyno numbers. YOu can loose 20+RWHP from the loss of timing, from just midly higher IATs. That is what tuning resolves.
No one ever got fired or sued for underating numbers. But Ford got sued for over rating the Cobras if you'll remeber. GM wants to ensure tha tthe worst motor will make 505. Those that come out slighly ahead, are just icing on the cake for the owners.
Also you'll find the loss in the driveline to not be a percentage, but rather a fixed loss. On a C5 its about 50-55HP going from a Superflow to a Dynojet. On the C6Z06 I don't know as there is more mass in the rearend.
J-Rod,
I definately agree about the IAT mapping for these cars. You can feel the power loss on the street as well its so noticable. We are still waiting for EFI Live to release there LS2/LS7 package as we are invested into there software. We are going right to that table as well as the PE Modifier as this baby is silly rich at WOT. Those numbers where at a AFR of 11.5:1 across the whole pull.
A couple degrees of timing shouldn't hurt either!
Howard
Old Apr 19, 2006 | 08:27 PM
GMW-CSL's Avatar
Looks like alot of good info. is coming out and will undoubtedly continue to do so. Once you tuner guys get finished with even a stock LS7 I'm sure you'll turn out some even more awesome #s.
