Logging C6 Z06 LS7 On Dyno - TPS?
Old Apr 19, 2006 | 10:18 PM
2xLS1's Avatar
Default Logging C6 Z06 LS7 On Dyno - TPS?
I logged 8 dyno pulls tuning a Z06 LS7 and never saw over 88% TPS at WOT. Anyone else seen this and is there any way to get it to go 100% TPS at WOT? Or is 88% on a fly by wire TB opening all the way?
Old Apr 20, 2006 | 07:10 AM
John B's Avatar
Moderator
Are you using HP Tuners? I see 88% on mine too, however, this is incorrect...it does open all of the way.
Old Apr 20, 2006 | 07:31 AM
2xLS1's Avatar
Yes, HP Tuners.
Old Apr 20, 2006 | 11:29 AM
Nemisis's Avatar
That seems to be a glitch in the HP Tuners software, thats the same thing that ocurred on my gto on the dyno.
Old Apr 20, 2006 | 12:06 PM
gun5l1ng3r's Avatar
So does the computer pull timing/ fuel when the TPS is at less than 100%?
Old Apr 20, 2006 | 04:30 PM
Nemisis's Avatar
No, the readings just don't match is all. When HP tuner is showing 88% or whatever the value is, it is in actuality 100%, it doesn't pull timing or anything like that.
Old Apr 30, 2006 | 07:35 AM
Flareside's Avatar
I have the same 88% problem with my C6 LS2 and HPT.
Old Apr 30, 2006 | 10:49 AM
John B's Avatar
Moderator
Have you tried logging in the table format? I believe it is correct there.
Old Apr 30, 2006 | 01:42 PM
Flareside's Avatar
Yep, 88% max in both the table and the graph.
