Reluctor wheel swap
Old Feb 17, 2008 | 08:34 PM
1BADAIR's Avatar
Originally Posted by greinder03
so i have a 07' ls2 and it has a goofy looking center bolt cam sprocket. i am putting a ms4 cam in which has the same bolt pattern as ls1. what sprocket do i need to get for it to work with my 2000 camaro computer, also what else has to be changes (knock sensor,cam sensor)?
the same sprocket that was posted. Knock sensors need to be used from your engine. Some drill and tap the stock ls2 knock holes. Others use the extra engine mount holes but sometimes the sensor gets in the way of the header
Coolant and oil pressure will have to be reused from your engine too
Old Feb 16, 2009 | 10:05 PM
InsaneDomestics's Avatar
You can keep the 58X reluctor wheel and still use your LS1 PCM, you just need the Reluctor Wheel Conversion Module That Lingenfelter Offers. I think its like $250 bucks or somethin. PN L460065397
