A little insight would be nice...
When you pull up to a stoplight dont push the clutch in till the last second before you stop so the engine will be pulling down and it may not try to shoot up. This is how I did it.
Thanks. I will remember that. So far, with the a/c on, all is reasonably well. I have learned that there "may" be a fix. I am taking it to my tuner tomorrow so we will see what happens. I still have the stock throttle body on but everything we have tried has failed. I understand from Doug at EC Tune that this is a problem with '06 mn6's and that the possible "fix" is through an update to the pcm through the dealership. Then the tuner can go from there. My dealership and tuner are about a block away from one another. Until it can be fixed though, I will just leave the a/c on. I do appreciate what you are saying because the only thing that helped prior to turning the a/c on was riding the clutch which I didn't like doing. I am hoping for progress on this tomorrow so keep your fingers crossed. Thanks again.
Robin
