VHP XXX Cam
Old May 3, 2006 | 09:32 PM
mhoglund's Avatar
Default VHP XXX Cam
Anyone running this cam in an LS1 F-body, GTO etc? I'm running the VHP 056 cam and I'd like to go a bit more agressive. My set up is Patriot stage 2 heads I believe they are 64 cc. Crane 1.8 rockers, 2800-3000 stall, Vhp 056 cam, K&N aircharger, SW LT's, Bassani cat back. Will the Patriot heads handle that cam? Thanks in advance.
Old May 3, 2006 | 09:50 PM
Phoenix 5.7's Avatar
never heard of it, any numbers for it? i think ur rockers will be ur biggest issue due to the 1.8 vs. 1.7 stock
8GTOKLR's Avatar
sure will. My buddy was running that setup. should be easy 400 wheel hp. the torquer 2 or magic stick will like too. Personally im running the 056 with stage 2 241's, 1.8 wont work due too xer lobes..based of crane zmax
Old May 6, 2006 | 09:02 AM
mrr23's Avatar
DUR @ .004" 284* / 290*
DUR @ .050" 222* / 228*
LIFT .551 / .551
OVERLAP 57*
LSA 115
and there will not be any issues with the 1.8 rockers.
here's the 056 cam you have.
DUR @ .004" 278*/ 286*
DUR @ .050" 216*/ 224*
LIFT .551/.551
OVERLAP 53*
LSA 115*
Old May 11, 2006 | 10:17 AM
mhoglund's Avatar
In your opinion, is there enough of a difference between the 056 and the XXX cam to make it worth doing? Or should I go bigger? I still want the low end torque and a good mid range.
