402/LS2 Head and Cam Reccommendations
Old May 8, 2006 | 12:59 PM
Doomsday's Avatar
Default 402/LS2 Head and Cam Reccommendations
Long story short, I blew a hole in my block.
Im looking to get a 402 LS2 shortblock. Im looking for a good head & cam combo to get 550RWHP. Of course, looking for this to have a streetable cam if possible. Thanks in advance.
Old May 8, 2006 | 01:12 PM
Orange Peel's Avatar
I would say a custom grind cam, talk to Ed Curtis, he knows this **** like no other! As for heads, go with some AFR 225's or something in that area, I have Dart 225's on mine, but they are burning oil and will be coming off shortly, hopefully for some AFR 225's. My cam is not that big, 236/244 .629/.629 114lsa, and with the Darts is made the numbers in my sig. 91 octane, 11.5:1+ A/F ratio with 21 degrees of timing.
Old May 8, 2006 | 01:44 PM
Doomsday's Avatar
"Its not that big", small it aint.
Thanks
Also, I will be going with a FAST 90/90. Any other suggestions.
Old May 8, 2006 | 01:47 PM
Well for a 402 it's mild, it drives awesome though
I got the FAST 90/NW 90, and it works awesome, next step is sheetmetal intake, which is a tad more $$
Old May 8, 2006 | 01:50 PM
LSxChevelle's Avatar
Looking at doing the rotating assebly below myself. Add the L92 heads, a nice cam, and the sheet metal intake/TB deal that Mizfit is doing and you should be close. That is the direction I would go if I wasn't planning on a Kenne Bell.
http://gmhightechperformance.com/tec...kit/index.html
Jason
Old May 8, 2006 | 01:54 PM
This looks like a great option! $1550 for intake, NW 90mm TB, and fuel rails. Oh yea, plus it's made for the L92's which are sweet and affordable.
https://ls1tech.com/forums/generation-iv-internal-engine/495980-gauging-interest-l-92-sheet-metal-intake.html
Jason
Old May 8, 2006 | 06:52 PM
yak's Avatar
yak
dude i'm planning on running a 244/252 on a 112 .620/.632 in mine .
Old May 8, 2006 | 09:38 PM
Doomsday's Avatar
Just trying to plan ahead just incase I cant get these numbers. Then I can plan on some spray to get me there. I dont really want to spray, but would like to keep it NA if I can.
Old May 8, 2006 | 10:25 PM
05_GTO's Avatar
It wont be cheap. As said talk to Ed about the cam and even the heads. AFR 225's are the way to go IMO. FAST 90 intake/tb. That should get you close but I wouldn't count on it, 550RWHP NA is not easy to do.
Old May 9, 2006 | 10:25 PM
KRAZY K 2000 TA's Avatar
Default 402 choices
I went with the SDPC 402 setup and could not be happier great service good prices,By the way this thing is an animal and a riot to drive you will love any 402 you get worth the coin mine idles good check my sig !
Old May 10, 2006 | 12:12 PM
Doomsday's Avatar
I guess I can settle for 500rwhp, cant be to greedy.
Old May 10, 2006 | 09:25 PM
Doomsday's Avatar
That being said, likely to run NA, there is many vendors doing 402 shortblocks. Texas speed, SLP, SDPC, etc. all are about $4000. I will just have to do some more research on the internals offered, my coins, and go from there. Damn, I still need heads, and FAST 90. I guess Im looking at about $7000. Makes me just want to rebuild my LS1 and spray it.
Any more suggestions?
Old May 10, 2006 | 11:26 PM
The low end torque of the 402 is worth the money spent dude! My shortblock was more than $4k, but I upgraded parts here and there over the standard stuff. It's all worth it in the end...... so they say
Old May 12, 2006 | 01:12 PM
Z O SICK's Avatar
I cant wait for my 402! I'm sure the tq will be great. If i can get 500rwtq in my car, it's going to be a beast!
Old May 13, 2006 | 09:22 AM
AU N EGL's Avatar
Originally Posted by 11secproject
Good info here.
