LS7 oil tank dimensions?
The measurements I took a while back showed the tank height at approx. 22.5" (top cast section to bottom cast section) and the cylinder is 6" in diameter. You also have to allow for the dip stick, two top line fittings and oil cap which raise the overall height dimension another inch.
We didn't have enough height to fit the stock tank and had to make a new section which was shorter but wider. If you do modify the stock tank a 10.5 quart capacity needs to be maintained.
Rich Lagasse
Rich Lagasse
We installed a LS7 tank in the C5 vette. It looks similar to this.
Click Here!!!
Click Here!!!
Hope that this helps. If you installing in another type of vehicle we might be able to help.
Chad
Click Here!!!
Click Here!!!
Chad
