Windage tray clearance on LS2 402?
Anyway, I put one (1) washer on each main stud, and now there is nothing touching. I rotated the engine over several times to make sure, and no part of the rotating assembly contacts the windage tray. In fact, the rotating parts wouldn't have hit it anyway, only the one main cap touched.
Is that correct? All it takes is one washer? The nuts on the main studs appear to be the same height as the stock ones, so that didn't give more clearance. I just don't understand why everyone would say "spacers", if all it takes is one washer. I've seen posts where people (with F-Bodies, though) say they even had to grind the oil pan itself, for rod-bolt clearance. And my rod bolts don't even touch the windage tray, let alone the oil pan.
Maybe I'm paranoid, but should Eagle and 4.0" be stamped on it anywhere I can see from the bottom end? It came with the heads on, so I can't just measure piston movement.
