What gaskets needed for LS2 swap?
Old May 19, 2006 | 08:24 PM
99vette pilot's Avatar
Default What gaskets needed for LS2 swap?
Is this kit comprehensive of all gaskets required to install an LS2 with pnp stageII heads from my blown LS1 into my 99' vette?
Complete New Gasket kit for a LS1 style Gen III engine. This kit will work with any Gen III 4.8L, 5.3L, 5.7L, 6.0L.
This kit comes with the following included
1 Set of Composite Head Gaskets(.060)
1 Set of Valve Cover Gaskets
1 Set of Intake Gaskets
1 Set of Valve Seals, Intake and Exhaust
1 Oil Pan Gasket
1 Intake Valley Pan Gasket
1 Front Timing Cover Gasket
1 Front Harmonic Balancer Seal
1 Rear Engine Cover Gasket
1 Rear Main Seal
1 Set of Steel Shim Multi Layer Exhaust Gaskets
1 Set of Water Pump Gaskets
1 Throttle Body Gasket
1 Oil Pump Pickup Tube O-Ring
1 Dipstick Tube O-Ring
1 Cam Position Sensor O-Ring
1 Crankshaft Position Sensor O-Ring
Thanks for the help.
