dod tunablity question.
Old May 20, 2006 | 07:20 PM
dogger's Avatar
Default dod tunablity question.
my question is concering gm's dod engine's. can you tune it or set it up so you can select when it's 4 or 8 cylinder? I mean by way of a switch so than you can drive when ever you feel like it in 4 cylinder for gas milage and then when you want to race or play hit a switch and be all 8 cylinders. I'm thinking of a asr switch set up.thank's
Old Jun 17, 2006 | 11:58 AM
Gm-LSX's Avatar
bump
I'm also iterestet in a "forced V4 Mode Switch" Will be nice for City Trafic around here. Mostly 60HP Fourbangers (in front of you)
Old Jun 17, 2006 | 12:27 PM
ringram's Avatar
Hopefully it will have map and/or rpm triggers, maybe even airflow so you can dial it in as you see fit. (ie) 0-40% throttle 4cyl, or 0-60kpa 4cyl etc or a combo of both.
