Need repinning Help
Old May 22, 2006 | 09:20 PM
jvrwong's Avatar
Default Need repinning Help
Does anyone know some one or a company who would be willing to repin a 98' Camaro harness so that it would plug into a 2006 ecm??? and run a 2006 LS2.
Thanks for the help.
P.S. Pulling the reluctor wheel off the crank is not an option I have anymore.
Old May 22, 2006 | 11:18 PM
GMW-CSL's Avatar
I'd say you've got a problem. Are the pin receivers in '98 Camaro harness major connectors compatible with the pins in a '06, LS2 ECM? Are the pin receivers compatible with the '06 LS2 major connectors you'll need to plug your wires into an '06 ECM? You're probably going to need alot of new connector plugs and have to crimp new connectors on the wires if it's even possible. I think I'd call John at Speartech and have him build you a new wiring harness to go with a new ECU to run that '06 LS2.
Old May 22, 2006 | 11:51 PM
GMW-CSL's Avatar
Find out if the individual pin receivers in your '98 major PCM connectors are compatible with the pins on an '06, LS2 ECM. If they are and they will fit into '06 major ECM connectors you may be able to make it work if you can get the pin-out for the LS2 ECU which I believe is available on this forum someplace.
Old May 23, 2006 | 07:49 PM
jvrwong's Avatar
Thanks, what I'm looking for is someone to do all that work for me, does anyone know of a company who would be willing to do it?
Old May 23, 2006 | 11:15 PM
GMW-CSL's Avatar
IMHO if you're willing to pay for it and you don't want to do it yourself call John at Speartech, without question.
