Rotating Assembly Sale @ SDPC
Old May 23, 2006 | 09:47 AM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
Default Rotating Assembly Sale @ SDPC
Spring Time at SDPC!
Time to clean house and make room for new inventory and our house cleaning is the perfect opportunity for you to save BIG Bucks on these spring specials. All items are on the shelf and ready to ship. Sale is limited to our in-house inventory and once the items are gone, the sale is over! Time to be an early bird and grab these savings while their available.
Rotating Assemblies
Need to upgrade your internals or looking to add some cubic inches? We have several 347, 384, 402, and 408 kits looking for a home. These are non-balanced rotating assemblies. We can balance these kits if you choose, add $227.00 for balancing. All kits are sold as listed, NO substitutions for different components.
347 Kits --- Save over $300.00
Includes: New LS6 GM crankshaft, Clevite-77 Main and Rod Bearings, Mahle Forged Pistons, Mahle File-Fit Piston Rings, and Scat 6.125” H-Beam Connecting Rods.
***Kit #1 – 347 Flat Top
Mahle Flat Top with 2-Valve Reliefs (-4cc), 3.905” bore
Approximate CR’s with 65cc Head: 0.055” Gasket - 10.1 to 1; 0.030” Gasket – 10.7 to 1
Kit Part Number - #1347FT – Sale Price $995.00
***Kit #2 – 347 Dish for Blower or Turbo set-up
Mahle Dish (-16cc), 3.905” bore
Approximate CR’s with 65cc Head: 0.055” Gasket – 8.8 to 1; 0.030” Gasket – 9.3 to 1
Kit Part Number - #2347D – Sale Price $995.00
384 Stroker Kit – Add some cubes to your 5.7L block! Save over $400.00
Includes: Eagle 4.000” Stroke 4340 Crank, Clevite-77 Main & Rod Bearings, Mahle Forged Pistons, Mahle File-Fit Piston Rings, and Scat 6.125” H-Beam Connecting Rods.
***Kit #3 – 384ci Stroker
Mahle Flat Top with 2-Valve Reliefs (-6cc), 3.910” bore
Approximate CR’s with 65cc Head: 0.055” Gasket – 10.3 to 1; 0.030” Gasket – 10.9 to 1
Kit Part Number - #3384FT – Sale Price $1554.95
402 & 408 Kits – Save over $400.00
***SOLD OUT******Kit #4 – 402 Small Dish
Mahle Dish (-12cc), 4.000” bore
Approximate CR’s with 65cc Head: 0.055” Gasket – 10.0 to 1; 0.030” Gasket – 10.5 to 1
Kit Part Number - #4402SD – Sale Price $1425.00
***SOLD OUT***Kit #5 – 402 Large Dish for Blower or Turbo
Mahle Dish (-32cc), 4.000” bore
Approximate CR’s with 65cc Head: 0.055” Gasket – 8.4 to 1; 0.030” Gasket – 8.8 to 1
Kit Part Number - #5402LD – Sale Price $1425.00
***Kit #6 – 408 Small Dish
Mahle Dish (-12cc), 4.030” bore
Approximate CR’s with 65cc Head: 0.055” Gasket – 10.1 to 1; 0.030” Gasket – 10.7 to 1
Kit Part Number - #5408SD – Sale Price $1554.95
Old May 23, 2006 | 10:05 AM
69firebird's Avatar
so its 1400 for a complete stroker kit?
thakns amazing if its true
ed
Old May 23, 2006 | 10:32 AM
bg-sdpc's Avatar
ed
That is correct.
Brian
Old May 23, 2006 | 10:44 AM
GuitsBoy's Avatar
My god thats an outstanding price! How much more for an LS2 block, covers and necessary ls1 conversion pieces?
Old May 23, 2006 | 11:21 AM
xfactor_pitbulls's Avatar
ed
No ****, I guess I will be getting a 408 sooner than I thought.
Brandon
Old May 23, 2006 | 11:34 AM
bg-sdpc's Avatar
$1575.00 for the block, dowels, pins, plugs, cam bearings, timing set, timing dampener, side main bolts, valley cover, front cover, and sensor harnesses.
Brian
Old May 23, 2006 | 11:37 AM
adams2003's Avatar
Can we get the discounted price on the rotating assemble right now if we buy a short block from you?
Old May 23, 2006 | 11:57 AM
No Juice's Avatar
Why are the 384 kits more than the 402/408 for the same parts? just curious
Old May 23, 2006 | 04:09 PM
White_Hawk's Avatar
Are those the Scat "LS1-Specific" rods? Awesome price regardless.
-Geoff
Old May 23, 2006 | 05:28 PM
LSxChevelle's Avatar
Thats a damn good deal!
Old May 23, 2006 | 05:36 PM
bg-sdpc's Avatar
Not a problem. We can do it.
Brian
Old May 23, 2006 | 05:37 PM
bg-sdpc's Avatar
-Geoff
Yes, they are LS specific..............
Brian
Old May 23, 2006 | 05:41 PM
bg-sdpc's Avatar
Quantity deal on 4.000" pistons.
Brian
Old May 23, 2006 | 07:26 PM
BIG BAD BLACKSS's Avatar
Only blower setup left is a 347 huh?
Old May 23, 2006 | 07:29 PM
stang90gt50's Avatar
Wow...Im a master WD for scat, eagle and mahle and I STILL think thats less than I pay for all that stuff.
BEST DEAL EVER.
Old May 24, 2006 | 09:14 AM
bg-sdpc's Avatar
I still have one of the # 4 kits left that could be used with a blower if you have a 72cc chamber head.
Brian
Old May 25, 2006 | 04:12 PM
bg-sdpc's Avatar
Brian
#4 kits are gone.........
Brian
