Meziere LS2/LS7 Electric Water Pumps Available!
Meziere has completed a production run for the new LS2 electric water pumps so we now have those in stock!
The LS1 pumps won't clear the LS2's throttlebody so Meziere had to make some changes. They put a relief in back of the pump body and milled a pocket to clear the throttlebody -
These pumps have been tested at the track, on the dyno and most importantly, during street driving. They have allowed engines to run cooler at low speeds and gain high end horsepower. In addition to the released power, you get to keep all of your factory accessories. Taking quality to the extreme, the WP319 features a dual bearing belt idler, billet parts throughout, and a “weather-tite” electrical connection. The pump is backed by a two-year warranty.
Features:
Purpose built for street use – 3000+ hour life expectancy.
Fully polished or anodized in your choice of 4 colors (Black,Blue,Red,Natural).
Chrome upgrade available.
55 GPM free flowing rating.
All stainless steel hardware included.
Heater and bypass provisions.
Light weight. Weighs only 14.9 pounds!
Stainless steel large diameter main shaft with high performance ceramic seal.
Inlet fitting supplied to match stock configuration.
Easy install - truly a "bolt-on" pump.
Full two year warranty - the best in the business!
Finishing The System:
This pump is supplied complete with gaskets and hardware, complete and ready to bolt on. The only additional item you will need is a standard Chevrolet thermostat if you desire to use one. It will install behind the exit fitting located above the idler pulley.
Amperage draw:
Under normal use the pump will draw 11-12 amps.
Overall Height Dimension:
The standard pump is 7.88" long from the mounting surface to the tip of the pump.
Pump Weight:
This application weighs 14.9 lbs.
We have an introductory of $519.99. This includes a free thermostat and free ground shipping in the 48 states. This price applies to the black pumps (most popular) along with blue, red, natural, purple and polished. Add $110. for chrome.
Orders can be placed online or by calling 1-877-482-9763. This price will be good through June 2nd.
Have a good day!
Features:
Amperage draw:
Pump Weight:
Have a good day!
