427 with LS6 ported Heads?
Old May 24, 2006 | 03:46 PM
Bill's 02 Z-28 SS's Avatar
Default 427 with LS6 ported Heads?
Hi Folks
I was considering the 402 but with so many options for the 427, the choice is easy - 427. However, here is the issue - I want to use my new 90mm TB and manifold, GM LS6 ported head. My car only has 6000 miles. I would like to use my old parts, mainly the heads, TB and manifold because they are new, about 2000 miles on them. Will the heads restrict the engine too much or should have fully ported or LS7 heads?
thanks
Bill
Old May 24, 2006 | 04:02 PM
NemeSS's Avatar
for the same price of having ur ls6's ported
u might as well go with some l92 heads,they flow better than 325 cfm
as cast and should pick up a few more cfm with a good valve job
and bowl work with the stock 2.16 valves
waiting for my set to come in so i can start working them
also waiting on my flowbench to come in though
im building a 414 ci around these heads 4.06 bore x 4in strk
Old May 24, 2006 | 04:08 PM
raymond mckinney's Avatar
Alot of people make great power on LS6 heads w/427's and ur sign says u have a 90/90 setup that's fine for a street car on Ls6 heads. U can make up to 550 or more wheel if u have a good set of Ls6 heads. There's no need to spend more money if u only have 2000 miles on some of ur parts. Just get a good cam and have some fun!!
Old May 24, 2006 | 04:21 PM
Cool_Hand_Luke's Avatar
What intake works with them? I thought there were some port/runner match issues.
Old May 24, 2006 | 05:34 PM
NemeSS's Avatar
well the intake hasnt been released yet
its an oz composite similiar to an ls2 intake,but its a 3 piece design so
it can be pulled apart for minor porting and radiusing.
i understand that there is single plane carb intake in the works for these heads
Old May 24, 2006 | 05:45 PM
Good to hear. I've been teetering between a 402 and a 427+ engine. The availability of a good flowing intake to match the L92 heads will be great for alot of builders.
Any idea of an availability date or testing data?
Old May 24, 2006 | 06:20 PM
69firebird's Avatar
if you just have the GMPP ported LS6 heads, that will be a hige restriction on a 427.
Id get the L-92 heads, or a set of Ls7 heads, sell your LS6 heads and fast 90/90, and get the Ls7 heads, they are about the best flowing heads around, and they are GM stock peices. Get those, and a LS7 intake, and you'll be able to push 600 rwhp without issue.
Ed
Old May 24, 2006 | 08:43 PM
11 Bravo's Avatar
Just have them ported LS6 heads set up for bigger valves and a 4.125 bore. Unless it was some cheap port job.
