Fuel Pump for 98 LS1 conversion to LS7???
Old May 26, 2006 | 07:44 PM
03 BUSA's Avatar
Default Fuel Pump for 98 LS1 conversion to LS7???
Most of the fuel pumps I see listed are for 99 and up. What is the difference from the 98's? Also in-line or in tank? I do not mind pulling the tank if an in tank is best. Also can you recomend a good fuel pump that is reliable and one that will have all the wiring for a plug and play? Thanks for your help.
Old May 26, 2006 | 09:09 PM
11 Bravo's Avatar
Racetronix.
Old May 26, 2006 | 09:52 PM
03 BUSA's Avatar
Are they really worth twice as much as the other pumps available??
Old May 26, 2006 | 10:00 PM
11 Bravo's Avatar
I don't know about the others, but Racetronix is a plug and play in tank pump. Working good on my setup.
Old May 26, 2006 | 10:13 PM
GoFast908Z's Avatar
not really no.
Paid 115 for my Walbro 255 on sale online. EXTREMELY easy wiring. And i hate wiring too, and it was still easy. The Racetronix you have to run extra wires to the engine bay I think. Sounds like a hassle, for a SLIGHT gain in upper rpm.
Old May 26, 2006 | 10:27 PM
03 BUSA's Avatar
When I saw the kit for the Racetronix it did look like a lot more wiring than the Wallboro. Is the Wallboro a direct replacement with no modifications to the tank? Also does anyone know the difference from the 98 and the 99 and up cars. I know the 98's came with a metal tank but did not know the pumps were any different.
