Are LS2 injectors longer or shorter than LS1 injectors..
LSxGuy widda 9sec Mustang
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Stock LS2 is shorter than LS1/LS6.
FAST Intake and Fuel rails...you'll need either stocker LS1/LS6 injectors at a minimum or the cheap way out for bigger injectors would be SVO 30lbers. FAST also has the right injectors available, think they may be similiar to the SVO's were in pricing.
For the harness, you will need adapter pigtails to plug in your LS2 harness into the older style fuel injector, or you can cut and splice.
The kit also comes with adaptors if you wanna run the LS2 fuel rail with the LS2 (or LS1) style injectors on the FAST intake.. I will snap a pic in a few days. Oh, the kit comes with new o-rings as well..
