LS2 6.0L Head Gaskets
Old Jun 7, 2006 | 11:55 PM
viewsonic's Avatar
Default LS2 6.0L Head Gaskets
Anyone know what the bore is for the LS2 GM MLS Head gaskets?
I think the P/N is 12498544
Old Jun 8, 2006 | 07:06 AM
viewsonic's Avatar
bumpp
Old Jun 8, 2006 | 10:58 AM
GFORCE1320's Avatar
I would assume that it is a 4.030 bore.
Old Jun 12, 2006 | 01:21 PM
viewsonic's Avatar
Default Mls Gaskets?
Well I am getting some ETP 225 heads (4.000 bore) for my LS2...
Here is my question:
I am looking at GM MLS head gaskets (P/N 12589227) And I wanted to know if they would work with my new heads.
I am worried that there may be some "overhang."
What do you guys think?
Old Jun 12, 2006 | 02:37 PM
viewsonic's Avatar
Anyone know?
Old Jun 12, 2006 | 02:38 PM
viewsonic's Avatar
Default Head Gaskets
Old Jun 12, 2006 | 05:41 PM
viewsonic's Avatar
bumpp
viewsonic's Avatar
bumpp
Old Jun 12, 2006 | 05:47 PM
mr2guru's Avatar
measure the chambers once you get the heads
Old Jun 12, 2006 | 06:17 PM
viewsonic's Avatar
Do you think the gaskets will fit fine?
I really wanted to get the gaskets the same time I got the heads...
Old Jun 12, 2006 | 08:13 PM
Abdullah's Avatar
i would say the LS2 head gasket would be the same as the iron 6.0L block.
Old Jun 12, 2006 | 08:18 PM
x phantom x's Avatar
STF veteran / 10 second club
Damn man, why don't you delete 2 of the 3 identical topic threads that you've created.
As long as your LS2 has the standard 4.00" bore, the 6.0 MLS will work fine.
Old Jun 12, 2006 | 08:41 PM
viewsonic's Avatar
I wanted to... But I don't know how to delete threads.
Yes I have a standard LS2. So the stock MLS gaskets should work fine with-out any over hang? correct?
Old Jun 12, 2006 | 11:05 PM
How about just not making 4 different threads in the first place?? I mean they all have different names so it's not like it was an accident??
Goto "EDIT" at the bottom of the first post of the thread, at the top click off the option to delete, then click "DELETE THIS MESSAGE".
Old Jun 12, 2006 | 11:33 PM
mr2guru's Avatar
Why? you're going to have to measure to get the right pushrods anyway. Then order them. So it's not like it will create additional down time.
Old Jun 13, 2006 | 01:05 PM
viewsonic's Avatar
I am ordering my cam ad heads from the same place... (FTI)
so ed should be able to know what size push-rods I need
