446ci with LS7 Heads
Old 08-18-2006, 08:56 PM
  #121
Haans249's Avatar
Interesting find....I just realized that I have the front timing cover off the L92 engine, which includes the L92 camshaft position sensor....
Does anyone know of that is compatible with the LS1 pcm? I'm guessing its no different, but if someone knows that it infact is not, PLEASE post up and let me know! Just making sure everything goes smoothly on install!
Adrian
PN is 12591720 for the sensor
Old 08-18-2006, 09:02 PM
  #122
11 Bravo's Avatar
The motor is looking good, bro. You're gonna love the torque. Stay safe in the box!
Old 08-18-2006, 09:20 PM
  #123
ramairws6's Avatar
Looks good there Haans! Getting excited for you myself!! Hope you got the bracket and all works out well for ya.Keep me up to speed. Traver
Old 08-18-2006, 10:33 PM
  #124
SLED28's Avatar
Originally Posted by Haans249
Well, the baby is done!!! Pics fresh off the press!!
Please, keep drooling at a minimum!
Dave...you're the man! A big thanks goes out to him for REALLY helping me out in this bind that I got into. Its great to know there is someone out there here to help someone in a tight spot...could'nt have been done with out you!
Tomorrow, I'm going to get that baby in the car and hopefully by monday I will be turning key. I'll post vids at that point!
Best Regards,
Adrian
Hey no problem buddy. Hope it works out well for you! See ya tommorow AM!
Old 08-19-2006, 11:26 PM
  #125
Haans249's Avatar
Well, I've got almost everything all wrapped up!! I just need the damn Coolant Drain plug!! What a bummer to not have something to simple, and IMPOSSIBLE to find.
Maybe someone has one local to me I can pick up tomorrow!? I'm working in Garden City, MI, but of course I can drive...just putting this out there. Its the large coolant plug that goes in the drivers side of the block.
Thanks!
Adrian
Old 08-26-2006, 11:37 AM
  #126
Haans249's Avatar
She was born 22 Aug 2006!! She started right up and man does she growl....
HUGE THANKS goes out to
Dave (SLED28), man does he really know how to build engines, and he really got me through a HUGE bind! Its been really great working with you!
Jason from Katech Engineering. He's come through for me with parts that I could not find anywhere else! Which includes arp flywheel bolts, arp crank bolt, UMI LS2/7 TB and the damn coolant plug! Thanks a lot for you help as well Jason, great guy.
More updates/vids to come soon! Working on the tune currently.
Adrian
Old 08-26-2006, 11:47 AM
  #127
SLED28's Avatar
Adrian
Well I'd like to say thanks for the opportunity!
Old 08-30-2006, 05:11 PM
  #128
wheeelzzz's Avatar
What kind of power does it make
Old 08-30-2006, 07:41 PM
  #129
gnx7's Avatar
dyno numbers this weekend? Can't wait to see what it does.
This is the cam you chose right:
242 XFI/ 255 XER .657/.655 Lift w/1.8's on a 111+3 LSA
And Katech springs/tit retainers?
Old 08-30-2006, 09:42 PM
  #130
LS1TECH Sponsor
Katech_Jason's Avatar
Christ on a bike! If that is the cam you chose this will be interesting. I hope you don't plan on cruising below 2500rpm.
Old 08-30-2006, 10:05 PM
  #131
Haans249's Avatar
Almost the cam...not quite it though...I'm running the following
242 XER/256 Renegade .646/.668 113+3 LSA w/1.8 ratio... it's a brute
Old 08-30-2006, 10:06 PM
  #132
LS1TECH Sponsor
Thats pretty wild.
Old 08-30-2006, 10:14 PM
  #133
Haans249's Avatar
Well....I've got EFILive with the new COSv5 with TPSvsRPM Ve Table tuning capabilities as well as other misc customized tables for fine detailing of the tune. So far, she drives like stock, with the exception of just a little hint of bucking (barely noticeable) from 1500-1700 rpms in 5th gear, most other gears are pretty smooth, and cruising down the highway in 6th is smooth as could be with AFR's pretty much on target in the street driving areas of the VE table in all gears. WOT is a little fat, but nothing to be too concerned over, but I haven't taken her over 4K rpms (42lb injectors at 50+% duty cycle with 2.5K rpms left) yet because its just too wild for the street....scares the **** out of me. A couple more days and a mustang dyno will get me right on target in the entire VE table, and I expect driveability to be awesome since so far just street tuning has come up pretty damn well....the beauty of a OLSD tune and EFILive!
I'm coming up there in the morning to get the racetronics pump kit installed at building #3, you can check out the car if you'd like Jason...I don't mind
Best Regards,
Adrian
Old 08-30-2006, 10:20 PM
  #134
LS1TECH Sponsor
Best Regards,
Adrian
Come get me when you drop off.
Old 09-01-2006, 11:53 AM
  #135
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Awsome. Keep us posted on your progress. I'm excited that this has come together for you on such short notice.
Old 09-02-2006, 08:59 AM
  #136
Haans249's Avatar
J-Rod, thanks for the kind words!! I finally hit the dyno yesterday....it was an "interesting" experience to say the least hahaha....
I get there, the guy who owns the Mustand Dyno wasn't there, although my vehicle was already on the rollers. Then the owner of the shop shows me some stuff and says..."Alright, have fun" and starts walking away. So, to make a long story short....I had to dyno my car, ALONE. First time to the dyno, and I have to run the dyno myself.
Did a little tuning and started to make some power runs. On my last power run, AFR was a tad rich (jumped between 11.8-12.3), but it pulled 497rwhp 435ftlbs. Now, this sounds horribly low and I thought the same thing...but then I asked the owner of the shop about it and he said their dyno is setup for tuning and will not give the "dyno queen" numbers people look for. For comparisons sake, another TA there, with a 427ci with ETP C5R 255 heads w/sheetmetal intake, true duals exh, made "only" 480hp to the wheels on their dyno. My exh is still your standard y-pipe setup with a flowmaster muffler, so that is choking the car down ALOT. So, add a dual exh setup, it'll probably see another 20hp/15trq conservatively on their dyno. So, I think my car did REALLY well for the setup. It still has a little work left to be done, but add that exh, touch up the tune and we're talking probably 520-530hp on their dyno which translates to 587hp/500 trq on a dynojet which I'd have to say, is pretty f'in nice...=D
Dyno graph inclose.
Thanks goes out to Jason at Katech, he stopped by the shop (which is across the street) to see how she was doing, and helped me out a little with the dyno. I appreciate it!
Best Regards,
Adrian
PS...Gotta love that FLAT trq curve =)
Old 09-02-2006, 11:36 AM
  #137
CNB
CNB's Avatar
Very nice torque curve! What rpm did you start with?
Old 09-02-2006, 12:47 PM
  #138
SLED28's Avatar
I think it peaked at 6500 so, if you count back, it looks like 2500rpm?... I think those lines are close to 500rpm each.
Adrian you did pretty good for the pressure! At least you can say you know how to run a dyno to your buddies Its too bad the guy wasn't there. Hope you had a good day today!
Old 09-03-2006, 10:06 PM
  #139
Haans249's Avatar
Yup, dyno starts at 2500 rpms and goes up to 6500, I couldn't figure out how to display the rpms in the horizontal axis, cause well, i've never run a dyno myself before
Old 09-03-2006, 10:21 PM
  #140
LS1TECH Sponsor
Theres a menu on the bottom of the screen for the horzontal axis. I changed it while we were looking at it.
Quick Reply: 446ci with LS7 Heads
