Cam for a 402
Old Jun 12, 2006 | 10:32 PM
jz06man's Avatar
Cool Cam for a 402
Cam For 402
I'm looking to upgrade to a 402 LS2 block/engine. I would like advise on cams- Now, I'm looking for a very streetable not bummpy cam! I'm looking to make as much torque down low and mid range with a good top end hp... I'm not looking to make peak hp or have a dyno queen.....
I'm looking to keep my LS6 intake & Patriot head, will this hurt much too much.... How much would a Fast 90/90 set add in the torque/HP department?
How much torque/hp would the cams you guys are recommending make?
Thanks
Old Jun 13, 2006 | 09:22 PM
jz06man's Avatar
Anyone...
Old Jun 13, 2006 | 09:48 PM
C5 KIDD's Avatar
wondering the same thing! i see a bunch of guys running forged 402's, but i cant find any HP #'s, or cam selections!!
c'mon guys... lets hear what your running, and what your putting down
Old Jun 13, 2006 | 10:21 PM
SSilverSSurfer's Avatar
Texas Giant from TSP, or the "E" cam from HPE...face it your gonna have to bump on that cam to get some power....lol
Old Jun 13, 2006 | 10:28 PM
KRAZY K 2000 TA's Avatar
check my sig thats SLP's 402 cam vey streetable,i love this cam cant hook up on drag radials either still have to air them down,idles great
Old Jun 13, 2006 | 10:42 PM
Blown04Z06's Avatar
'04 Z06 LS2 403Ci
im going to be going with a custom grind .608/.621 242/250 LSA 114+3
LS6 intake ported, LS6 TB already ported, LS6 heads ported and milled with stock size valves head flow will be 314-315 cfm @.600, compression shoud end up 11.3:1
ported fast 90/90 will be added by the end of the summer
Old Jun 13, 2006 | 10:56 PM
that should idle nice and sound great to.Im in love with my car since my 402 girlfriend is jealous.but never told me to go slow.
Old Jun 14, 2006 | 12:53 AM
jhong321's Avatar
Originally Posted by jz06man
Cam For 402
Thanks
I have pretty much the same set with you 402 ,ls6 intake, patriot ls2 stage 2 heads . I was running a 226/226 112 cam and it put out 473 rwhp and 490 rwtq. I then switched over to a 230/234 114 and loss a little hp and quite a bit of tq. (470 rwhp - 470 rwtq) I have been told that the ls6 intake is now the bottle neck in my set up. I plan on testing out a fast 90/90 to see what will happen. hoping to get about 490 rwhp. As for now the car is very streetable at low rpm. good luck with your choice.
Just rember bigger is not always better .
Old Jun 14, 2006 | 06:13 AM
See5's Avatar
Comp Cams XTREME XE-R XER281HR - 232/234 - .595/.598 w 1.7 rocker - 112 LSA
Looking for a more tame torque centered motor.
Old Jun 15, 2006 | 08:06 PM
jz06man's Avatar
Does anyone have a video or sound clip of their 402 at idle and/or reving???? This would help since "good idle" is very subjective.....
Jhong321, intresting on the 226/226 LSA 112 with the hp & tq numbers..... I was looking at a 228/228 LSA 114, but then have been told to go higher to the 232/236 LSA 114; however I'm concerned about the idle quality..... What lift do you have with this cam???
Thanks!!!
Old Jun 15, 2006 | 09:57 PM
DrkPhx's Avatar
I have a link of my 402 idling in my sig.
Old Jun 15, 2006 | 10:09 PM
beardWS6's Avatar
Cam in sig with A4 on my 408. Made 500TRQ all threw, very flat TRQ curve. Also runs and idles awsome! I could be making more power, but the LSX intake is choking my ET heads bad on [eak power. Working on that now.
Cam 244 248 612 615 113lsa
Old Jun 15, 2006 | 10:32 PM
11SECDWS6's Avatar
FWIW, here is my 408:
http://media.putfile.com/idle1-18
http://media.putfile.com/idle2-24
Old Jun 15, 2006 | 10:33 PM
StickSS's Avatar
Default Katech CTS-V Cam
Hi: What about the Ktech CTS-V cam that was designed for a 427 in a Caddy CTS-V. Read an article in a magazine it is suppose to idle good and be smog legal. It is a 226/226 116 with 585 lift using 1.85 rockers. Don't know of any one is using it. Maybe give them a call about it.
Old Jun 16, 2006 | 01:01 AM
C5 KIDD's Avatar
Originally Posted by 11SECDWS6
sounds sweet! what cam are you running though? ive changed my mind again and im going with the iron 408. im going to call jeremy formato this week to see what he recommends, since he will be tuning the car once its complete. so far the t-rex (smaller) and texas giant (larger) are on the top of the list. or might get a custom grind. so many choices
those are some pretty nice numbers. torque is very impressive, wouldnt mid something similar!
Old Jun 16, 2006 | 01:36 AM
67camaro's Avatar
maybe a XER 228/234 .588/.595 110 LSA
Old Jun 16, 2006 | 04:49 AM
11SECDWS6's Avatar
Hey thanks bud. It is a camotion cam. 244/250 .630" lift on a 114+4 LSA. I got it through LME when they built the 408. The cam is VERY streetable. I am sorting out some converter/transmission issues so the power output is TBD.
Old Jun 16, 2006 | 05:35 AM
See5's Avatar
Brian @ Comp cams recommended a 238-242/605-610/113 XE-R
Old Jun 16, 2006 | 07:27 AM
mikey's Avatar
LS1TECH Sponsor
Call me....
Mike
Old Jun 16, 2006 | 07:44 AM
walker94z28's Avatar
I ordered a 402 from TSP and I had a Texas Giant put in it.
