TSP 402 Texas Giant #'s
Originally Posted by C5 KIDD
those arent the specs.
just ordered mine last week... lift is .614 .622
The advertised specs are .611 .613. All cams wont grind out the exact same, mine were a little different, too.
Man, I would expect more torque? I have the same cam in my 422ci LS6 and although I put up decent numbers 518 / 483, I would think a cam this size would do a little better. I waz expecting in the 530 / 500 range. I might change out the cam and see how it does. I'm going through a 90 / 90 and kooks 1 7/8, I just dont have a pulley. hmm.
do you have your graph? I had a small dip in the RPM right around 2500rpm that we couldn't seem to get rid of.
Originally Posted by NemeSS
can u please post the cam card specs
i am looking to use this cam in my motor, need to know the valve events
so i can figure my DCR
Originally Posted by Smartass6885
was that through a Flowmaster cat-back, or true duals with flowmaster muffs???
-Blaze
-Blaze
No i made 575 ftlbs at 3700 rpm and 475 hp at 7100. The numbers have definetly changed since i dynoed but i havent been back yet and i am currently changing ingnition and the compression is comming up
575 is not accurate because that is a torque spike from the converter flashing. That is why it is at 3700, and not a typical higher value. You need to lock the converter up and roll into the power to avoid a downshift and a graph with a torque spike.
