LS1 to LS2 conversion Questions! HELP!
Old Oct 17, 2006 | 02:53 PM
Randy WS6's Avatar
Yes move the ones under the valley cover and put them on the side of the block and you will need the extension wires for the knock sensor
Old Oct 17, 2006 | 03:19 PM
Dragaholic's Avatar
9 Second Club NA
Cool, so I was right.
Old Oct 17, 2006 | 08:40 PM
Black93Z28's Avatar
i already purchased the extensions but i was confused to where they were, i thought they were in the valley cover but i didnt realize they could be removed.... i actually just went out and removed them and screwed them in the ls2.
Old May 3, 2009 | 08:55 PM
Jditlfm's Avatar
bringing this back from the dead. So can anyone confirm using a 8.5mm drill bit first before using the tap im having a hard time with one. Also in a f-body configuration is there ant ill effects of using one of the other 10mm open holes instead of the lower ones?
Old May 3, 2009 | 09:12 PM
HSV-GTS-300's Avatar
Old May 5, 2009 | 07:40 PM
WARP211's Avatar
What is the benefit of converting a LS1 to LS2?
Old May 5, 2009 | 08:53 PM
RoDan's Avatar
LS2 is 1 faster.
Old May 5, 2009 | 09:05 PM
Randy WS6's Avatar
The stock LS2 is 4.00" bore and plus you can over bore it .030" for a total of 4.030" witch is what i have.
Old May 18, 2009 | 07:54 PM
WARP211's Avatar
Originally Posted by RoDan
LS2 is 1 faster.
Faster how? calculating parameters? I kno a LS2 has a bigger bore. But whats the benifit of converting your LS1 to a LS2? When you are just changing a few sensors and a valley cover? Yet you keep the same LS1 block..
Old Oct 21, 2010 | 07:13 PM
ShevrolayZ28's Avatar
Good tech thread here. Thanks. I did mine today using a 10x1.5 tap and a 11/32" drill bit. Like buttah.
PS I've also read that an 8.5mm drill bit works.
https://ls1tech.com/forums/5107895-post4.html
Old Feb 5, 2011 | 05:07 PM
JoshuaGrooms83's Avatar
more power? thats what i always thought? lol
Old Feb 5, 2011 | 08:55 PM
  #32
TransWS6Am's Avatar
dead thread........
Old Feb 6, 2011 | 05:37 AM
  #33
only if people let it i was thinking about this and was wondering what peoples experiences were with it.
Old Apr 7, 2011 | 10:11 PM
  #34
01redws6ta's Avatar
Ls2 conversion allows you to use the new and far superior ls3 heads. Most people only do the ls2 conversion after their ls1 grenades.
Old Apr 7, 2011 | 10:17 PM
  #35
TransWS6Am's Avatar
or the LS3 conversion after thier LS1 grenades
Old Apr 9, 2011 | 09:28 PM
  #36
01redws6ta's Avatar
Even better yet...your setup looks quite impressive and car looks badass. Have you had it dynoed or been to the drag strip?
I just noticed you are from B.C.? I'm a little less than an hour away...I don't see too many of our cars around here!
