White smoke coming from driver side of engine?
Old Jul 8, 2006 | 01:37 PM
mulletwearingtadrive's Avatar
Default White smoke coming from driver side of engine?
So I was driving my car today and as I came to a stop a bunch of white smoke came up from my driver side fender and through my vent on my dash....
i popped my hood and it looks like its coming from somewhere around the header/spark plugs....it smells kinda fruity or sweet or something like that, my friend brandon said that its probably coolant, any idea what is wrong?
Whats weird is that the white smoke comes out when I hit my brakes really hard.....my brakes feel fine and sound fine
ALSO, my e-break light is staying on
Old Jul 9, 2006 | 12:09 PM
anyone?
Old Jul 9, 2006 | 12:45 PM
hondo's Avatar
brake fluid leak??at the master or somewhere around there dripping onto something hot.
Old Jul 9, 2006 | 01:06 PM
if it was break fluid would it be white smoke?
Old Jul 9, 2006 | 04:43 PM
JPATI's Avatar
Default problems
You need to take the car to a shop and have the cooling system pressure tested. Is you antifreeze in the radiator low? Is your brake fluid low? Maybe you just have a coolant leak and it splashs on the exhaust when you hit the brakes hard.
Old Jul 10, 2006 | 12:53 AM
****...didnt think about that. i will take it in asap and see what i find out....
Old Jul 12, 2006 | 03:48 PM
formul8's Avatar
You may have blown a head gasket.
Old Jul 12, 2006 | 03:57 PM
Haans249's Avatar
Lets not all jump to conclusions guys....First off, tell us exactly what you have done the past couple days, how you've been driving, and or what things mechanically you've done...including the foot powder bit Any new noises? Check all of your fluid levels and pin point where the smoke is coming from. That'll help a lot.
Old Jul 12, 2006 | 04:13 PM
i have been driving pretty normal, nothing crazy, no racing. just my daily routines: the gym, school, work, etc. the smoke seems to be coming from between the master cylinder and the header...and it comes out noticeably when i hit the brakes.
if it was a head gasket would it have anything to do with me hitting the brakes? that doesnt seem right.....
Old Jul 12, 2006 | 04:33 PM
00'WS6Rocket's Avatar
my guess is small brake leak.. Make sure your brake fluid lid is on tight/all the way... Hot antifreeze doesn't smell fruity, it smells fishy
Old Jul 12, 2006 | 04:35 PM
don't think this is the problem but ..if its blown head gaskit check the oil and look to see if its milky
oh ya whats that green thing sitting next to the t/a?
Old Jul 12, 2006 | 06:26 PM
Haans249's Avatar
Its an Elise
Old Jul 13, 2006 | 01:32 AM
yeah it's an elise...my friend's 05. cool car, but not my cup of tea....
i will keep checking things and see if i can figure out what is going on...
Old Jul 22, 2006 | 09:13 PM
ok so we figured it out and it was the EGR rubbing against the brake line going from the reservoir to the abs module.......good thing we caught it when we did cause it was getting rid of my brake fluid quick.
we got a new line and installed it and relocated it away from the egr tube
thanks for all the help guys
Old Jul 23, 2006 | 04:03 PM
Glad you found the problem before it turn in to something worse!!!
