what is Stock LS2 of Crate Engine Cam specs
Old Jul 9, 2006 | 08:40 PM
BadLtBlu99TA's Avatar
Post what is Stock LS2 of Crate Engine Cam specs
What is the Specs on the O5 LS2 crate engine .... 24x redulator WHats the cam specs and what is the Starting RPM range of the Stock cam and the ending RPM range , basically im trying to find out what kinda converter to get for my built transmission
Old Jul 9, 2006 | 11:31 PM
Default LS2 cam
WHat is a decent size cam i can put in my ls2 without having to tear into the heads , i just wanna replace the cam if possible without having to do head work ? what kinda lift can the stock heads on an 05 LS2 crate engine handle , and what kinda extra HP am i looking at ? what RPM spec is the cam good from and to ...
This is going to be a daily driver so i dont need nothing too big ..
Old Jul 9, 2006 | 11:58 PM
Bring the Noise's Avatar
204/211-.525/.525-116lsa listed by Someday in post https://ls1tech.com/forums/generation-iv-internal-engine/212470-what-ls2-s-cam-spec.html
The Stock LS2 springs should be good up to .550 lift.
Piece of mind... get the Comp 918 kit (springs, ti retainers, and 7.4 rods) goes for around $500 and it's a strait swap for the stock springs and allows you to go with a cam that goes up to .600 lift.
Part # Comp 54100
Old Jul 10, 2006 | 07:25 PM
cool thanks man
