LS2 402 cam choices?
I went with this cam: 239/248 .649/.615 110LSA +1 with LSK/XER lobes
Being finished now, hopefully running in 3 weeks.
LS2 Block
Callies Racemaster Crankshaft
Callies Compstar Connecting Rods
Diamond Forged 4.005" Pistons
Speedpro Rod, Main Bearings
GM Cam Bearings
AFR 225cc TTP Stage 4R Port/Polish
GM OEM Lifters
Stock Rockers TTP Pushrods
I've read the LS2 blocks don't hold up well with a big shot of N2O. Aren't you worried about your setup?
LS2 Block
GM Cam Bearings
GM OEM Lifters
eagle crank, lunati pro mod rods, custom coated dimond pistons,
out of the box afr 225's
comp lifters, comp push rods, stock rockers, fed mog bearings, bla bla bla.
as for the big shots, you heard it, but who has accually tested it?
im hitting mine with 300-350, plan on going to 400-450, so until some one proves it, im the test dumbie. lol
do you know anyone who has accually had an issue that was do to the block?
his cam was speced by tony at afr
