ET cylinder heads
Old Jul 19, 2006 | 07:29 AM
wheeelzzz's Avatar
Default ET cylinder heads
I have just installed a set of ETs 215s. My car makes good power UP TO 6500 Then it falls off. Its not my camshaft my tuner tells me it in the heads valve springs. I have called ET they tell me its my lifters. has anyone else had trouble with ETs heads. Not trying to bash anyone just want my car to make power up to 6900 rpm.
Thanks Wheeelzzz
Old Jul 19, 2006 | 08:55 AM
JakeFusion's Avatar
Super Hulk Smash
If you reused your stock lifters and they have some miles on them, then it could be them sticking at high RPM. Otherwise, it could be the springs or too short of a pushrod or too heavy of a rocker. Did you resue the stock rockers?
Old Jul 19, 2006 | 09:19 AM
Rick@Synergy's Avatar
Do a search for some Dyno Graphs on ET heads, they all look the same. I dont think its your lifters.
Rick
Old Jul 19, 2006 | 09:24 AM
Louis's Avatar
Let me see the graph.
Old Jul 19, 2006 | 10:38 AM
JakeFusion's Avatar
Super Hulk Smash
ET 225s on an LS2 with an EDC custom cam. This is from Nick's GTO aka viewsonic. Of course, the valve springs are FTI upgraded springs...
Old Jul 19, 2006 | 11:42 AM
JL ws-6's Avatar
Race your car!
I don't see any problem with the above dyno graph that makes me think that the springs aren't up to par.
To the thread starter, if you reused your stock rockers, then they are most likly fine. Are the springs that came on the heads been shimmed at all? I'd think that they shoudl be to withing XX amount of coilbind. What is the camshaft like? Is it very aggressive? More info needed to help determine the problem.... but from what you are saying, if the car's got enough fuel system to support the setup, then I'd have to agree with the tuner, it probably is in the valvesprings/valvetrain.
Again, if the stock rocker arms were reused and are good, and if the stock lifters were reused and they were o.k., then I"m gonna have to say the springs need to be shimmed/looked at.
Old Jul 19, 2006 | 11:44 AM
wheeelzzz's Avatar
Here is my sheet
see how it falls off over 6200
Old Jul 19, 2006 | 11:52 AM
RyanJ's Avatar
SSU Moderator
Kinda looks like a dip vs. a real drop...but that could be a weird dyno spike at the very end, who knows. Who is your tuner? What are your cam/engine specs?
Also, you're complaining about 480rwhp?
Old Jul 19, 2006 | 11:54 AM
Craig@ETPerformance's Avatar
To be honest with you it looks like it is the lifter problem in this case because the curve comes back up. From the graph it drops off around 6200 then comes back up at around 6600 - 6700. If it is valve float the horsepower and torque will drop off and not come back just keep dropping off.
Old Jul 19, 2006 | 12:16 PM
viewsonic's Avatar
Yup my ET heads keep on pulling to 7K (Which is where my tuner let off the gas)
I do have the upgraded FTI springs (PS4's) good upto .650" lift
THESE ARE THE NICEST LSX CYLINDER HEADS I HAVE EVER SEEN!
And my tuner Jeremy Formato believes these are the nicest heads that money can buy!
Old Jul 19, 2006 | 12:17 PM
wheeelzzz's Avatar
Well i went down to my tuner to ask him about lifters & he gave me a dyno sheet from a different zo6 with ET 215s and as you can see it has the same dip. How can lifters be bad in two different engines. I just want to get to the bottom of this. He also thinks its valve springs.
I have found this what do you guys think. Will this spring work.
I just resolved this problem. I did a lot of research and even considered a stronger dual spring. I realized that staying with a dual spring was not fixing the problem but just covering it up. I set out on a quest to reduce mass on the valve side without buying expensive titanium valves. I installed Comp's new 26120 beehive spring with titanium retainers. I re-dynoed the car and the power holds to the rev limiter! You will have to purchase new valve seats with the 26120 but it is worth it. Comp seriously underrates this spring when they advertise it but it will work.
Old Jul 19, 2006 | 12:44 PM
viewsonic's Avatar
uhh.... why did your car lose 40 peak hp and 20 peak tq?
Old Jul 19, 2006 | 12:51 PM
wheeelzzz's Avatar
The 2nd dyno is not my car its a different car with the same problem.
Both cars are low mileage so how can the lifters be bad.
Old Jul 19, 2006 | 02:23 PM
2001 Pewter WS6's Avatar
Restricted User
What springs did you get with your ET Performance heads??? My build sheet said I have the Crane springs... Are these the ones in question???
Old Jul 19, 2006 | 03:42 PM
JL ws-6's Avatar
Race your car!
I'd be intrested to know which springs they are as well....
Old Jul 19, 2006 | 03:51 PM
02ZOh6's Avatar
My 215's have PSI 1225's. I don't think et is using the 977's anymore. Just putting the car back together so no graphs as of yet.
Old Jul 19, 2006 | 03:59 PM
Let me start this off a different way, because may be wrong with my first initial statement.
What is done to the engine with the camshaft specs? Can you pm me your Serial # on the side of the head so I can figure out what chamber size and valve spring are on there. Can you also if possible post the air\fuel ratio graph and total timing that is used?
Thank you,
Craig
Old Jul 19, 2006 | 04:05 PM
RyanJ's Avatar
SSU Moderator
I don't see how anything mechanical would produce a "dip" in the curve like that...but I'm sure I have less experience in this area than most of you. Who is this mysterious "tuner"?
Old Jul 19, 2006 | 04:49 PM
JL ws-6's Avatar
Race your car!
Questions for ETperformance while we're at it, what are the standard springs that are rated to 650... and how do they compare to say the patriot golds? I'm surious as to wether they will be enough for what I have in store for them. Please take this to PM if you need more details as to what heads I have, setup, etc. Thanks.
Old Jul 19, 2006 | 05:01 PM
pianoprodigy's Avatar
I have ETP 215s milled to 59ccs that will be used with a G5X4. Will my springs hold up?
