L92 crate + W2W =
Old Aug 1, 2006 | 08:08 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by chicane
Uhm.... A 4.125" bore with a 4.0" stroke = 427.6 cid .....to include a 70cc chamber and a 0.038" head gasket.
A 4.125" bore with a 4.10" stroke = 438.3 cid .....with the same attributes.
Or you could use a 4.075" bore with a 4.10" stroke. But bore vs. stroke ratios are better when going towards a larger bore vs. stroke.
The L92 isn't a 4.125 bore.
From the sticky:
Type:
6200 6.2L V-8 (L92)
Displacement (cu in / cc):
378 / 6199
Bore & stroke (in / mm):
4.06 x 3.62 / 103.25 x 92
Old Aug 1, 2006 | 08:56 PM
Reckless's Avatar
Super Moderator
Thanks, I thought I was misreading that post
Old Aug 1, 2006 | 09:28 PM
vanilla89's Avatar
i read it was 4.065!!!
Old Aug 1, 2006 | 09:35 PM
OWN3D BY MY PROF!
This is what bg-sdpc said on 6/9/2006 in the L92 Blocks and Heads @ SDPC:
Originally Posted by bg-sdpc
No, it comes with a 4.065 bore. I will probably on go out another .010", maybe .020".
You're correct, it was probably just rounded with 3 sig figs.
Old Aug 1, 2006 | 10:00 PM
TPIMarow6.6's Avatar
Good luck with the progress on your project, like everyone said, the main part is over with, now fitment, rear end strength ect. im willing to help as much as i can! ill get you those pics probably later tomorrow.
Old Aug 2, 2006 | 04:51 PM
slt200mph's Avatar
Very kool project..keep us posted on the progress..
Old Aug 2, 2006 | 11:01 PM
chicane's Avatar
Originally Posted by Beaflag VonRathburg
So, I saw you used a 4 inch stroke. Is there any way that a 4.1 inch stroke will fit for a total of 427ci? I know it's onlt 11ci, but if all it takes is a longer stroke you might as well.
Make sense now ??
Old Aug 3, 2006 | 10:27 PM
HotRodV6's Avatar
I thought that the L92 4.065 bore combined with a 4in stroke crank made 416 cubes not 414?
Ok, well some quick math and it lookslike it comes out to 415.299 cubes, So actually it should be called a 415 cube L92.
Old Aug 4, 2006 | 07:18 AM
Reckless's Avatar
Super Moderator
I thought it was a 4.060, so I just guessed 414
Old Aug 4, 2006 | 07:36 AM
kumar75150's Avatar
u are worthless Todd
Old Aug 4, 2006 | 07:37 AM
Rock_Daddy's Avatar
I should have my build up sheet soon and I guess it will show its actual stock measurement and then whatever they cleaned it up to as new pistons went in.
Ill let everyone know all the build specs as soon as I get them. I bet it is really a 415 or 416 too.
Old Aug 4, 2006 | 03:39 PM
  #32
OWN3D BY MY PROF!
Make sense now ??
No, all you did is highlight my question? Your response was helpful just not in context to what I was asking.
Old Aug 4, 2006 | 03:55 PM
  #33
guinness2's Avatar
Originally Posted by Reckless
414 CID
So, how much does it cost and does it fit in an F-body with those heads they look big!!
