L92 crate + W2W =
Old Jul 31, 2006 | 08:41 AM
Rock_Daddy's Avatar
Default L92 crate + W2W = 414 CID powered Vega
Hot off the presses.
I handed off a new truck crate motor to W2W and received back a nice big bore stroker upgrade to my 1976 Vega. I’ll start posting progress pics at my personal site www.ls1vega.com
They got rid of all the cylinder deac stuff and the entire cam phaser assembly,lifters, oil pump and seems to have turned it into a good old big bore Gen III with the sweet L92 heads of course.
W2W custom cam (forgot specs but will get, don’t have build sheet yet)
Springs, pushrods and Ti retainers to match.
A full rotating assembly (Callies 4 inch, Callies rods, Mahle pistons)
Custom W2W oil pump
11:1 comp.
I have the stock truck intake of course but no other options in my possession.
Here are some pics of it and of the box of stock parts taken out(lots of them)
I want to thank everyone at W2W for the great work!
If W2W steps in they can tell you allot more about the build then I could at the moment.
Old Jul 31, 2006 | 08:54 AM
jdo6696's Avatar
sounds cool man, but all I see are red x's.
Old Jul 31, 2006 | 08:56 AM
Rock_Daddy's Avatar
I got the W2W red x special.
Anyone else seeing red x's?
Old Jul 31, 2006 | 09:28 AM
93Polo's Avatar
Pics work for me. Cool looking project
Old Jul 31, 2006 | 09:29 AM
Rock_Daddy's Avatar
Cool. Yeah the easy but more expensive part is done. Now to make it work.
I'm looking forward to the fun of it though.
Old Jul 31, 2006 | 09:45 AM
ringram's Avatar
That truck intake looks messy
Old Jul 31, 2006 | 10:22 AM
Reckless's Avatar
Super Moderator
414 CID
Old Jul 31, 2006 | 12:12 PM
gun5l1ng3r's Avatar
I agree
Old Jul 31, 2006 | 12:17 PM
viewsonic's Avatar
+1
Go for a sheet metal intake
Old Jul 31, 2006 | 12:19 PM
chuntington101's Avatar
looks nice
so how much?????
Chris.
Old Jul 31, 2006 | 12:33 PM
Rock_Daddy's Avatar
Well its the same cost really for a stroker LS2 setup plus cam, springs retainers and push rods. Then of course the price of the crate motor.
Since I have a Vega I wasn't someone just waiting for a block which seems to not be happenning too fast. I have nothing and needed everything so I just started with the crate motor.
It wasn't cheap or anything but you get what you pay for so I figured I do it right once and just eat peanutbutter and jelly for a while.
I forget the cam specs but I'm attempting to get a build sheet from Billy. Them maybe some would like to guess at HP after I get some cam details.
Old Jul 31, 2006 | 12:40 PM
LSxChevelle's Avatar
That's gonna be a sweet setup!!
Old Jul 31, 2006 | 01:50 PM
Haans249's Avatar
Where in Michigan are you? I'm working on my 446 CI LS2 in Garden City, MI. I'd love to drop by and check out your project!!
Shoot me a PM!
Adrian
Old Jul 31, 2006 | 03:03 PM
Kenova's Avatar
I've taken a good look at them. Unlike the older one piece truck manifolds, they are made in three pieces then glued together! I wonder how much boost it would take to crack one open?
Ken
Old Jul 31, 2006 | 04:47 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
So, I saw you used a 4 inch stroke. Is there any way that a 4.1 inch stroke will fit for a total of 427ci? I know it's onlt 11ci, but if all it takes is a longer stroke you might as well.
Old Jul 31, 2006 | 05:12 PM
chicane's Avatar
Uhm.... A 4.125" bore with a 4.0" stroke = 427.6 cid .....to include a 70cc chamber and a 0.038" head gasket.
A 4.125" bore with a 4.10" stroke = 438.3 cid .....with the same attributes.
Or you could use a 4.075" bore with a 4.10" stroke. But bore vs. stroke ratios are better when going towards a larger bore vs. stroke.
Old Jul 31, 2006 | 05:52 PM
Rock_Daddy's Avatar
I'm not really sure what had to be done if anything for a 4 inch stroke and what the max stroke that is possible. Actualy I don't know what its finish bore is yet. I will have all the info on the build around friday.
I just left it to the pros at W2W
Old Jul 31, 2006 | 11:41 PM
Nate_Taufer's Avatar
Originally Posted by Reckless
414 CID
Hey Todd, did you guys see if a 4.1" stroke would fit when putting this block together? Or are the sleeves not long enough?
Nate
Old Aug 1, 2006 | 01:30 AM
cantdrv65's Avatar
Man. That light *** Vega is going to rip!
Old Aug 1, 2006 | 07:58 AM
Reckless's Avatar
Super Moderator
Not sure about the fitment on a 4.1" crank. The crank is not the issue, the issue is rodd clearance. We are getting ready to start an LS7 with a 4.250" crank. It will require custom Ti rods though. So I am sure it could be done, but there might be added expense.
