ARP Head Stud torque specs needed
Old Apr 26, 2012 | 03:48 PM
Half-bred's Avatar
Not to steal the thread, But Does anyone use copper coat on the head gasket its the
LS9 gasket or do you put the gasket on dry??? Please Help
Old Apr 26, 2012 | 03:58 PM
LSHUNT's Avatar
I put copper coating on mine.
Old Apr 26, 2012 | 04:13 PM
Half-bred's Avatar
Thanks,
Old Apr 26, 2012 | 05:08 PM
69_YENKO's Avatar
I used copper coating on mine also.
Old Apr 26, 2012 | 07:14 PM
Old Geezer's Avatar
Be aware that ARP has a "new" lube. They claim it reduces "torque scatter".
Also, I do the torque process, wait over night, and check.. Most ALWAYS I find low readings...
Old Oct 15, 2015 | 02:59 PM
LS1-450's Avatar
Originally Posted by Pumba
I have just completed a 2.5 hour tour of the Earnhardt-Childress Racing Engines shop in Welcome, North Carolina.
During that visit I had a discussion with their R&D Shop Foreman about cylinder head attachment for the LS engines. ECR has determined that the LS heads move around on the engine, even when naturally aspirated, when the cylinder heads are torqued using the method shown above. What they now do using ARP 12mm studs that have been turned down to 11mm outside of the threads that go into the block, is to torque the studs 85 lb-ft. Then they loosen the nuts completely, reapply ARP's thread lube, and retorque the studs to 85 lb-ft. again.
They stated that the retorquing eliminates head movement, and shows a significant improvement in gasket sealing and a more uniform distribution of the clamping load across the gasket. The important thing to take away from the information that ECR Engines provided is - AFTER YOU HAVE COMPLETED YOUR INITIAL TORQUING OF YOUR CYLINDER HEAD STUDS, REMOVE THE NUTS, APPLY A FRESH COATING OF THREAD LUBRICANT - BEING SURE YOU DO NOT GET ANY LUBRICANT BETWEEN THE WASHER AND THE CYLINDER HEAD, AND RETORQUE THE NUT.
How does a head that's doweled (roll pins) to the block move around? Agree w/ better gasket sealing, but, other than thermal expansion, how can it move? Would also limit the 85 ft/# suggestion to those using studs... or on iron blocks when using bolts. Bolts add a torsional load to the block threads where studs do not.
Old thread, but, needed comment.
Old Oct 15, 2015 | 04:41 PM
Pumba's Avatar
Originally Posted by LS1-450
How does a head that's doweled (roll pins) to the block move around? Agree w/ better gasket sealing, but, other than thermal expansion, how can it move? Would also limit the 85 lb.-ft. suggestion to those using studs... or on iron blocks when using bolts. Bolts add a torsional load to the block threads where studs do not.
You are assuming that your block to head dowels are keeping the entire head from moving, including the portion between the dowels. You are also assuming that the heads are not lifting.
According to Earnhardt-Childress Racing Engines both assumptions are bad.
Old Oct 16, 2015 | 02:27 AM
LS1-450's Avatar
Haven't assumed. Am sure that lifted, spread, opened, gap increase between head & block...etc. was meant in the ECR post, but, not used. The term moved is vague. I noted thermal expansion. There can be no lateral movement between dowels other than from the thermal expansion occurring over the entire head. This has nothing to do w/ head stud torque.
This entire bolt torque thread is all over the place & can cause someone w/ an aluminum block to damage their block threads. If using bolts in aluminum, do not over torque.
Old Oct 16, 2015 | 08:37 PM
S10xGN's Avatar
Originally Posted by Slowhawk
For the LS2's it say's 80ft/lbs on mains and 25 ft/lbs on the smaller bolts with there lube. Just did a set. It use to be lower.
I did mine at 90 and 28.
Just did my mains, so while were here...
There's only one main kit for the (factory) LS, #234-5608. I had to call ARP and verify this, as that PN shows "Chevrolet Small Block LS1 cast iron Main Stud Kit" (the tech I talked to said he's been after their web dept to change that description for years). The sheet I have (and it's current) shows 60/50 on the 10mm bolts and 20 on the 8mm bolts. Not saying it won't work, but 90# is a huge increase from 60/50# and could possibly deform the bores...
Old Feb 12, 2017 | 10:09 PM
white01ss's Avatar
Default Specs changed again?
Just downloaded this from ARP... now it's 100/28 ? WTF
Old Feb 13, 2017 | 07:53 AM
KCS's Avatar
KCS
Moderator
That's for the CA625 alloy.
Old Feb 13, 2017 | 08:01 AM
  #32
Double06's Avatar
I think also at some point the stock cylinder head has not enough thickness to take advantage of this higher torque. The aftermarket heads have thicker deck surfaces and can take more clamping force. I have an ERL block and they recommend another 10 ft pounds or so on after market heads. On the ZR1 motor the heads/block have a 12 mm stud and I think are like 120 pounds of torque - I am sure that is a lot of fun to do in the car.
Old Feb 28, 2017 | 12:36 PM
  #33
white01ss's Avatar
Default Standard ARP studs
Sorry for the confusion! Didn't know there were two levels now. The 234-4313 and 234-4314 sets are higher strength CA625 and over $1000 a set! My standard studs 234-4317 are in the $4xx range.
I talked the ARP tech support and he said "100 ft/lb from a set from 2010, I don't think so... Those are only for the the high hp race studs. (CA625)" He said they actually lowered the torque on the standard studs from 80 to 70 because folks kept lubing the bottom of the washers causing the nut to get way tighter that it was supposed to and snapping off studs in the block. Sounds like you could do 80 if the washers and head mating surfaces are clean and dry.
Another tip he said was to rough up the bottom of the washers with some low grit sandpaper to give them extra bite on the head to prevent rotation.
Posting this to prevent folks from snapping off head bolts... 70 ft-lbs official from ARP.
Old Mar 11, 2018 | 07:54 PM
  #34
BennyB's Avatar
Old thread, but after reading most people say 70# and 22# for head studs while the instructions from ARP said 80# and 25#. I ended up using 75# and 25#.
Old Nov 20, 2022 | 04:48 AM
  #35
Loneriderme's Avatar
I don't know how old this thread is but I just ordered headstuds for my Ls1 Gen 4 and the instructions state 30 1st pass,60 2nd pass ,90 3rd pass and 28 on the small bolts? I wish they would make up my mind,I guess I'll have to call them.
Old Nov 20, 2022 | 10:07 AM
  #36
01CamaroSSTx's Avatar
Cmon man, you don't know how old the thread is? Just look at the last post and that'll tell you.. I haven't seen BennyB on here in ages but I've used that same torque 30,60,90 for the ARP studs on the 427 and 370.
Old Nov 20, 2022 | 12:40 PM
  #37
no I didn't look at the date pee pee!!
Old Nov 20, 2022 | 11:20 PM
  #38
wannafbody's Avatar
I've seen some torque videos and the ARP lube was the most accurate tested.
Old Nov 24, 2022 | 07:57 PM
  #39
grinder11's Avatar
I'll say this: It depends on what ARP fasteners/studs you're using. According to ARP, the ARP 2000 stuff has a different torque value than their other stuff. FWIW-I've NEVER had them tell me 80lbs.....
