L92 Heads/Intake - Cam Question
Old Aug 30, 2006 | 11:03 AM
  #41
Quik's Avatar
Originally Posted by SStrokerAce
These things aren't going to need intake duration, and until you get flow numbers on a 4.0" bore your not going to know the split. Even then they will still want more exhaust duration than that. These heads are made like any good NA race head, HUGE intake valves, as big as you can get in there and small exhaust valves. We are talking a diameter/circumfrence ratio of 73% compared to 77% in standard LS or SBC heads. When we get flow numbers on the smaller bore and with intakes and exhaust pipes then it should give us a better indication of how much split, but even so it's still going to be more than 10 degs difference at .050", so the traditional LS cams will not give the best results.
Bret
so your saying most LS cams wont work that well with those heads then? since the split is minor compared to some more radical split durations like 20*+
Old Aug 30, 2006 | 11:17 AM
  #42
SStrokerAce's Avatar
Yes,
Believe me I'm a proponent for the least amount of exhaust split as I can put in a street motor, but when you see 350cfm intake and 220cfm exhaust there is no way around it. Now combine that with the fact that these intakes will move 20-30cfm more than a LS6, LS2 or FAST 90 then it's going to make it worse not better.
Your not going to be able to run a TRex or FM13 with these things, in fact I think those are going to be too big on most of these setups. These heads will be a balancing act, but if it's right they will be driveable AND make power.
Bret
Old Aug 30, 2006 | 11:37 AM
  #43
Quik's Avatar
Yes,
Bret
so Trex on a 408 wont be as effiecent as a good set of worked ls6?/fast90/90 setup on a 408 with 11.4CR compared to a Trex on the L92/L76 408?
Old Aug 30, 2006 | 01:20 PM
  #44
Uhhhh.... I don't design motors around cams so the heads and intake come first. If you made a cam for the L92/L76 it would be better. That answer your question?
Bret
Old Aug 30, 2006 | 02:42 PM
  #45
HEMIETR's Avatar
So I understand this. What would a generic spec cam be that would work well with these heads?
Old Aug 30, 2006 | 05:12 PM
  #46
tmoneyr007's Avatar
Maybe something like this? Honestly don't have a clue, just trying to keep people talking.
http://www.lingenfelter.com/store/ls1-gt1-1.html
229/242 .631/.631 w 1.7 rocker 114 CL
Old Aug 30, 2006 | 05:32 PM
  #47
StreetnStrip's Avatar
Closed ex-Sponsor Account
Ilike mine better but mine is a lingerfelter cam.
Old Aug 31, 2006 | 05:47 AM
  #48
ringram's Avatar
I think you will find the longer LSA of stock L92 cams is for emissions not power.
If you tighten that up you will reap the benefits of scavenging on the intake. Perhaps open the exhaust a little earlier and hold it open longer. Of course lift it high and fast too to make the most of the high initial pressure. The large intake will act like a larger duration and lift on the intake lobe anyway. Look at the pressure difference between atmospheric pressure for intake and combustion pressure for the exhaust.
Duration of exhaust will be determined on how long it takes to exit the exhaust gases, some interesting trial and error over the next few month I think. Katech seems to have a good head start on the LS7 cams which should be closer in spec to L92 cams than LS1 cams. IMHO.
Old Aug 31, 2006 | 05:53 AM
  #49
That's getting closer, I'm going to need some more hard numbers to give a solid answer. Generic depends on the application, a LS2 short block is different from a 402. I don't have 4" bore ported numbers and all the data out there. We are probably talking smaller intake durations than what we normally think due to the CSA of the intake port and 15+ degs of split most likely just because of the flow bias. It's like LS7 cams, I don't think people are going to be putting the specs out all over the place when they get something that works. A lot of people have learned NOT to do that because of all the standard LS1 and how cam centric it is.
Bret
