l92 comp. question
Old Aug 16, 2006 | 06:29 PM
WYD-01's Avatar
Default l92 comp. question
we are building a 414 l92 headed motor. Planning on using gm head gaskets. Any thoughts on 11.0:1 compression or 11.5:1. Leaning towards a 200-250 shot of gas. We have concerns about cylider pressure and blowing a head gasket. Any input is appreciated
Old Aug 17, 2006 | 12:37 PM
SStrokerAce's Avatar
Why just the GM gaskets? Cometic can make you whatever you need and are hella strong as well.
The only issue with GM OEM castings is the deck thickness on a N2O motor.
The 11-11.5:1 compression is fine, depending on the gas and the cam you could go higher or lower.
bret
