How much power from 441"
Old Aug 15, 2006 | 12:14 PM
David Gordon's Avatar
Default How much power from 441"
I am talking to a sponser right now about building me another great set-up and this time going all out on a 441" using LS7 parts with a medium size cam.
I searched and cannot find any HP numbers from these size motors.
Please post up what you guys are seeing.
Thanks DG
Old Aug 15, 2006 | 12:37 PM
vmax1500's Avatar
Thanks DG
I would ask the sponsor... honestly, there are too many variable... I would guess 600-700HP at the crank depending on how radical you choose to go...
Old Aug 15, 2006 | 12:45 PM
kumar75150's Avatar
probably 560-570 with a mid size cam
Old Aug 15, 2006 | 12:46 PM
Haans249's Avatar
I agree with Andre, you should be able to make close to 700 to the crank no problem. You just have to spec out your cam properly, and make sure you're running good compression.
What are the specs on the engine going to be? What are you going to use? I was doing a 446 not too long ago that fell through the day I was supposed to get the engine...not too happy about that. I'm now getting a 427 and should have it by this weekend if everything goes well.
Adrian
Adrian
Old Aug 15, 2006 | 01:11 PM
It will be a LS7 block with a 4.125 crank (I already have it from previous set-up) LS7 heads and I will let TS pick the cam.
Thanks DG
Old Aug 15, 2006 | 03:01 PM
Haans249's Avatar
You can't run a 4.125" crank in the LS7 block because the sleeves are too short. You'll end up pulling the piston out of the hole too much to the point where the rings will come out....VERY bad. The largest you should go is 4" on the LS7 block.
If you want to be able to use a 4.125" crank, then you'll need to get it resleeved with Darton LS7 sleeves which can accomodate a 4.25" stroke. Also, depending on how much you can find a LS2 block for, you can end up with a better block then the LS7 for less then the cost of a LS7 block.
Also, using a 4.125" stroke will make for some poor pistons, as the ringlands will all be really smashed together if using a 6.125" rod because the Compression Height will be too small.Yyou should call Eric at Diamond Racing so he can help guide you with options for pistons so they can make you a good quality piston.
Now, if you're building a straight race motor that will be rebuilt year after year, then forget the last bit about the pistons
Best Regards,
Adrian
Old Aug 15, 2006 | 03:35 PM
I dont believe it is a straight LS7 block it has some work done to it.
Old Aug 15, 2006 | 03:49 PM
Haans249's Avatar
What work? If it has been resleeved, then you're golden, if not, then you're toast to use a Stock LS7 with a 4.125" stroke. The only way you can run that big of a stroke is to get new sleeves, there are no other options.
Old Aug 15, 2006 | 06:36 PM
Beast96Z's Avatar
I think you may have your info misconstrued. Why in the world would GM shorten the sleeves on a motor that comes with a longer stroke than a LS1 block? I have full confidence that the sleeves in the LS7 block are at minimum, the same legnth as the LS1 sleeves, and will fully accept up to a 4.250" stroke if you want that crowded of a ring land. He could run a 4.125" stroke no problem, but I wouldn't throw to much of a power adder on top of it due to the lands being a bit tighter. A 4.250" stroke would be very tight, but manageable for a N/A application. All the above strokes have been crammed into STOCK LS1/6 blocks with no problems. There's no reason why you couldn't do the same with a LS7.
Old Aug 15, 2006 | 07:16 PM
Haans249's Avatar
Show me somewhere where someone put a larger then 4" stroke on stock sleeves and didn't have the engine fail.
Its not just the ringlands that you have to worry about, its how far the skirt comes out as well, cause if you pull it out too much, the piston will rock at BDC, and toast your pistons skirts/cylinder walls. The engine won't last longer then one season, if not one week.
You can't run longer then a 4" stroke on stock sleeves and expect the engine to last....end of story.
Adrian
Old Aug 15, 2006 | 07:27 PM
redaddiction's Avatar
Adrian
I've got a stock sleeved lq9 block with a 4.125 stroke and zero problems. It's possible in the lsx motor.
Old Aug 15, 2006 | 07:29 PM
briannutter's Avatar
Default sleeve length. helping out for the greater good.
Don't be so quick to determine what stroke will and will not work. Piston skirt design on custom pistons is a variable and it's your duty to know the sleeve length of your motor (if you're building a stroker). If your piston company goes "huh?" when you bring up the subject, you better move on to one that's knows something about building engines-because they're going to screw up another 9 variables that I didn't tell you about.-Brian Nutter
Old Aug 15, 2006 | 08:30 PM
Haans249's Avatar
Well, i'll shut my mouth then, I just figured he didn't want to build a time bomb and burn oil.
I talked with Diamond, so I'd hope they know what they're doing.
Best,
Adrian
Old Aug 15, 2006 | 08:44 PM
Beast96Z's Avatar
Adrian
Come on man, you posting up misinformation. If your unshure about something, sit back and let others answer. I don't try to know like I know every question that comes out, unlike some on here. It dosen't help anyone and could ultimately cause someone some extra expense. I'm not sure how long you've been around LSX motors, or your back ground with anything else so I'm not going to bash. One thing I have noticed, you asked alot of questions, FAST, when you got here. If that's the only info you have in your aresenal, it's not enough. The guy who started this thread has had a 4.125" stroked 396 for as long as I can remember, that's one. Another is Kumair. I know he's had his 4.125" stroked 396 for well over 50k miles from what I remember. I think that is well over a season or 3. Not to mention multiple others on this board. It's actually a very common motor for those wanting to buy the Lunati kit. The reason they aren't that popular is because no one wants to pay $4k for the Lunati kit, and it is just that, a Lunati 396 kit for STOCK sleeves w/ a 4.125 stroke crank. G-force racing on here built the Impala with a STOCK sleeve and the 4,250 stroke, as far as I know, it has been and still is cranking out big numbers with no problems. It was even publicized in GMHTP if you want to look back for it. My motor was almost built with a stock legnth sleeve and the 4.185" stroke crank, but the longer sleeve was only a $300 option, so I got better spacing out of that deal. Either way, it could have been done, no problem. I'm not trying to bash in any way, but take it easy when it comes to saying something can't be done, because in this case, it totally can.
Old Aug 15, 2006 | 09:34 PM
Haans249's Avatar
Wow, that really amazes me, I didn't think it would be possible with stock sleeves and I haven't heard of anyone yet who has a motor lasting with an arm that big on stock sleeve length. I've talked with guys with lots of experience in this realm, but I guess I have to take everything with a grain of salt until i see if for myself. God damn I hate being that guy... Sorry for causing an argument over something that I realize I didn't know anything about. On to more research for this guy right here...
Best,
Adrian
Old Aug 16, 2006 | 05:09 AM
Texas Speed built mine over 3 1/2 years ago and I have had no problems at all with it.
Thanks for the input guys!!
DG
Old Aug 16, 2006 | 01:11 PM
Haans249's Avatar
https://ls1tech.com/forums/showthrea...66#post5366766
Here is an interesting post about the sleeves in a LS7 block. Verifies what Beast was saying! Probably some very interesting info for you Mr.Gordon. You could probably run a 4.25" stroke crank in that LS7 block with little worry, but don't quote me on that
Old Aug 16, 2006 | 04:36 PM
Beast96Z's Avatar
Sorry if I sounded harsh in my post man. I'd just been in a fight with the old lady and I was venting in the wrong place. There's 2 things that don't mix with the internet, women and alcohol...
Old Aug 17, 2006 | 10:45 AM
supercoupe01's Avatar
Thanks DG
I have an ECS447 LS6 Darton block with LS6 stage three heads with a medium size cam making 570/540 at the wheels running pump gas. Most have not been getting much more with LS7 stuff yet. Two years and still running strong.
Old Aug 17, 2006 | 11:35 AM
vmax1500's Avatar
Those are some impressive numbers... have you had the car at the track yet?
