ls7 potential
Old Aug 25, 2006 | 11:29 AM
Stang's Bane's Avatar
Default ls7 potential
Another hypothetical situation here. How much are the ls7 ported heads capable of n/a. I am trying to figure out what I can produce within the limits of the parts I already have. Right now all I have is the block and pistons. The block is a 4.11 bore and the pistons are a set of Diamonds with a -7 dish. What are some of your opinions? I am looking at compression between 11.8 and 12.2 or so. Really leaning towards a sheetmetal intake. Car will not see much street duty, but I do want to be able to drive it to local car shows and such. Maybe a little late night fun too I don't have a problem with going solid roller, or almost anything else. My goals are well above 600 rwhp, but the most important is very solid 10's at the track. M6 car that will have a 9" and probably 4.10 or deeper.
Old Aug 25, 2006 | 01:16 PM
John B's Avatar
Moderator
With a sheetmetal intake, larger throttle body, fully ported heads and wild cam 700RWHP should be a slam dunk.
Old Aug 25, 2006 | 01:19 PM
Even given my SCR limitations? just asking, because I have NO idea.
Old Aug 25, 2006 | 02:02 PM
gnx7's Avatar
I thought the minimum bore size for LS7 heads with stock valves was 4.125"?
Old Aug 25, 2006 | 02:24 PM
4.10" is the minimum.
Old Aug 25, 2006 | 02:35 PM
gtovan's Avatar
Corvette Doctors just finished a Z06 w/ 13:1 cr using the stock LS7 intake and reworked LS7 heads. It made 640+ rwhp thru the stock mufflers w/ a moderate cam.
http://forums.corvetteforum.com/show....php?t=1474740
Old Aug 27, 2006 | 09:32 AM
I should have been more specific. Car has got to run on pump gas. If I can get 650 I will be pretty stoked.
Old Aug 29, 2006 | 09:39 PM
Bump it up
Old Aug 30, 2006 | 01:38 PM
mike c.'s Avatar
i have a ls7 427ci w/ls7 reworked heads and intake being built for next spring. i really feel sorry for the people i sereet race against. LME is getting over 600hp to the wheels w/a mild cam in it.
Old Sep 1, 2006 | 04:43 PM
Any more opinions on the capability of the LS7 heads? On PUMP GAS.
