F-Body with LS6
Old Aug 27, 2006 | 03:47 PM
STKN1STGEAR's Avatar
Default F-Body with LS6
Hi,
I have a 99 SS camero with LS1, that I just blow the motor in. I would like to know if you think it would be better to put an LS6 in instead of the LS1? I would also like to know if it will bolt up to the 6 SP trans? what else do I need to look at? or would it be beter to put an LS2 with a supercharger? I have the superchager already. any ideas would be great?
Old Aug 27, 2006 | 04:02 PM
LSGunZ28's Avatar
LS2 because it has a bigger bore
Old Aug 27, 2006 | 04:15 PM
Doesn't the LS6 Also have a bigger bore?
Old Aug 27, 2006 | 04:19 PM
Rynofasho's Avatar
Originally Posted by STKN1STGEAR
Hi,
Buy a honda.
Old Aug 27, 2006 | 04:20 PM
Rynofasho's Avatar
Nope
adillhoff's Avatar
LS1 and LS6 block are the same with the exception that the LS6 block has ported oil passages. They will all bolt on to the T56 fine.
Old Aug 27, 2006 | 04:35 PM
Originally Posted by Rynofasho
Buy a honda.
No Rice for me I like meat and potatoes
Old Aug 27, 2006 | 04:37 PM
LSGunZ28's Avatar
LS6 is the same bore and stroke as the LS1 with the exception of different a cam and heads. Also I think the cmpression may be different along with a breather hole in the block somewhere. that is all Im assuming.
Old Aug 27, 2006 | 04:40 PM
Nope
so other that the ported oil what else is differant?
Old Aug 27, 2006 | 04:42 PM
BOWTIE's Avatar
As mentioned, heads and cam are different and possibly the intake depending on what year LS1 you have.
so if I reuild the LS1 andput a new Z06 cam and heads then I have an LS6?
Old Aug 27, 2006 | 04:43 PM
it is a 99 SS. I think that the LS6 also has forged pistons and connecting rods ? yes?
Old Aug 27, 2006 | 04:50 PM
LS1Aggie09's Avatar
use search
Old Aug 27, 2006 | 05:07 PM
THE_SUPRA's Avatar
please leard how to spell
Old Aug 27, 2006 | 07:56 PM
sorry for the typo.
please look in the mirror.
Old Aug 27, 2006 | 08:00 PM
mpe488's Avatar
Go for the LS2. It has more torque, and more potential with the extra displacement. 400rwhp with bolt-ons means easily 500 with H/C. I wouldn't even get power-adders or a stroker if I could make 500 N/A so easily.
Old Aug 27, 2006 | 09:40 PM
Stang's Bane's Avatar
I agree, go with the LS2. However, 500 rwhp is not easy. Even with the extra displacement, you have to have a pretty nasty(read BIG) cam and top notch heads to see 500 rwhp n/a. Very, very few cars I have heard of hit 400 with just bolton's also. If you already have a supercharger go ahead and use it. Which one is it?
Old Aug 27, 2006 | 09:55 PM
moeZ28's Avatar
NOPE.
Old Aug 27, 2006 | 10:05 PM
It's a vortec 9PSI w/aftercooler
Originally Posted by moeZ28
NOPE.
Please explain
