can a 402 do over 500 rwhp?
Old Aug 30, 2006 | 06:09 PM
ZDOG's Avatar
Default can a 402 do over 500 rwhp?
can a 402 do over 500 rwhp with a ton of torque? im trying to decide and staying na or go with an ati on a stock ls1. id prefer na.(maybee with a hundred shot on top ) the car is a 02 camaro m6, mostly driven on the street with light to light runs and some spirited moments on the highway.any suggestions?
Old Aug 30, 2006 | 06:10 PM
adams2003's Avatar
Yes....I believe they have put down 550rwhp before.
Old Aug 30, 2006 | 06:22 PM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
Mikey from Rapid Motorsports had one go 553 rwhp
Old Aug 30, 2006 | 06:23 PM
hyde's Avatar
Mine with LS6 heads made 515...Im about to due alil more head work and i am shooting for 540 RWHP...I have a vette so they make alil less than what a camaro would make....Just a heads up
Old Aug 30, 2006 | 06:33 PM
mike c.'s Avatar
why would a vette make less power then a camaro w/a 402ci? the rapid 402 did make 553hp,but it was on a 10bolt w/342 gears,electric water pump things like that that gives more hp#'s. a 12bolt w/some gear will take 20hp off that # real quick. i'm looking at rapid for my new motor build up this winter.
Old Aug 30, 2006 | 06:34 PM
98Z28CobraKiller's Avatar
Restricted User
You would get a lot better driveability out of an FI 346 making 500 wrhp than a 402 NA IMO
Old Aug 30, 2006 | 06:40 PM
mike c.'s Avatar
98Z28 COBRA KILLER-does your 402 have bad driveability? what were the #'s on your 402ci?
Old Aug 30, 2006 | 07:01 PM
sbcgenII's Avatar
a 402 can make 500 no problem.
Originally Posted by mike c.
why would a vette make less power then a camaro w/a 402ci? .
Drivetrain.
Old Aug 30, 2006 | 07:06 PM
98Z28MASS's Avatar
yes!!!
Old Aug 30, 2006 | 07:19 PM
Restricted User
It's not real bad but I am still working out the bugs. I don't have the dyno numbers yet asI am trying to figure out a fueling driveablity issue that I hope was resolved by the new racetronix pump that I put in. Have'nt had a chance with the "Killer Storm" that we have had to deal with for the last few days here in South Florida.
I am saying that you can put a blower on a stock long block with a stock cam (drivability) thru some opened up intake and exhaust and run 500 rwhp no problem.
Old Aug 30, 2006 | 07:21 PM
theblur98ss's Avatar
If it doesn't make close to 500 at the wheels it would be a waste of money in my opinion.
Old Aug 30, 2006 | 07:24 PM
98Z28MASS's Avatar
402 with a good sized cam (say a 240/248 or so), afr 225's or an etp equivalent, fast 90/90, 1 7/8th kooks will get you there. I say go 402 as you can hit 500 rwhp on a stock internal ls1 but even with a real good tune and fuel system you will eventually need to get a forged 346 to up the boost, so then you looking at $6000 for the ds1c with the 8 rib setup and then another $3600+ for a forged 346/347 short block, then a set of good heads, etc...My vote is for forged 402!
Old Aug 30, 2006 | 10:32 PM
Blown04Z06's Avatar
well since i had a P1 charged '04 Z06 518/459 i would say that drive ability with the blower is not more streetable. there is a ton of unuseable power after 4k RPMS. it comes in late. also my motor blew 2k miles after the insall. IMO your stock LS1 will not last, forge your bottom end if your going to put a blower on it. Im now building a 403 with everything that will be put on it and into it we are expecting 530/490 on 93 octane. 238/.621 112 cam, 6spd, 3.42's, aluminum flywheel.
Old Aug 30, 2006 | 11:56 PM
black_knight's Avatar
To answer the first poster:
402's ROUTINELY go over 500 RWHP. 550 is more the norm. Anyone making under 500 with a 402 has something strange going on.
Old Aug 31, 2006 | 07:30 AM
11 Bravo's Avatar
550rwhp is in no way more the norm that 500 on a 402. Those motors that make outrageous numbers may be more visible because they get the 5 page threads in the dyno section, but the average guy building a 402 should be happy with 500, and not be dissapointed if it makes a little less than that in the real world.
Old Aug 31, 2006 | 07:37 AM
Restricted User
There are other factors on the dyno. M6 is gonna dyno higher than an A4. Stock rear will dyno higher than a 12 bolt, S60, or ford 9". Also, height of the tires, etc.
Old Aug 31, 2006 | 07:40 AM
Restricted User
As far as FI vs. big cubes big cam. I think that the best setup (wish I had done it) would be to get yourself into a 9:1 compression forged 402/408 with a medium cam (high 230's dur 114 LSA) and then slap a turbo on it. After all, it's only money .
Old Aug 31, 2006 | 08:00 AM
KAOS's Avatar
not to hijack what about a 383? with all the right parts, would 500+ be a problem
Old Aug 31, 2006 | 08:05 AM
If you haven't cheaped out on the heads or intake, then I would say 550 would be the number to expect. The proven combos are out there and it's just a matter of following them. That is of course assuming M6, dynojet dyno, etc etc. (adjust that # to fit if you have a drivetrain that takes more)
And if you have less than 500rwhp with a 402, then as I said something strange is going on. Something that can and in most cases should be corrected. Again, that is with an M6 and dynojet. Show me a 402 making under 500 and I'll show you a combo that is not optimized.
Old Aug 31, 2006 | 08:06 AM
Tony Mamo did a 383 a bit back. Look up his thread and you will see 500+ is no problem for a properly set up 383.
