Katech sneek attack 346, 8000 rpms?!?
Old Sep 3, 2006 | 12:55 AM
99blancoSS's Avatar
Default Katech sneek attack 346, 8000 rpms?!?
I'm shopping for a new setup. I'm guessing this is a solid roller? Any ideas on the power band?
Old Sep 3, 2006 | 02:29 AM
Wnts2Go10O's Avatar
short stroke, big bore. lots of torque, lots of rev happy horsepower. im gonna guess the powerband will look similar to an ls1 but...more..
Old Sep 3, 2006 | 02:59 AM
DONAIMIAN's Avatar
I cant see it having a lot of TQ, but I can see it having some nasty top end.
Old Sep 3, 2006 | 03:14 AM
Nate_Taufer's Avatar
You're not gonna be able to spin it that high unless you have a dry sump setup at the minimum. Definitely have to be solid roller. Not really what you would want for your intended goals 99blancoSS
Nate
Old Sep 3, 2006 | 04:21 AM
99SS-T's Avatar
X2. Short stroke big bore is GREAT for high RPM and hp but horrible for TQ. Just like most race engines that rev to teh moon. Got about 2" of stroke to get that high and they let the rpm's do the job.
I would love to have a NA engine with no nitrous that can make 700 and rev to 8k. Sounds like a Nascar engine. GL guys
John
Old Sep 3, 2006 | 11:12 AM
99blancoSS's Avatar
Nate
I was thinking that might be the case but it caught my eye so I thought I'd get some info on it.
Old Sep 3, 2006 | 02:29 PM
Cop Car's Avatar
its probably a 4.125 bore with a 3.26 stroke.. that is the set up that i want..
Old Sep 3, 2006 | 09:56 PM
Katech_Jason's Avatar
LS1TECH Sponsor
It uses a modified production lifter.
Old Sep 4, 2006 | 01:12 AM
99blancoSS's Avatar
Can you provide some power numbers or dyno graph? PM me with pricing info as well if you dont mind.
Old Sep 4, 2006 | 01:28 AM
KCFormula's Avatar
FYI Tim Tosto spins his LS1 to 8100rpm through the traps with stock oil system. However for reliability I have heard the most you want to spin is about 7500 before the pickup starts getting starved for oil.
Old Sep 4, 2006 | 01:38 AM
Quick1998Z28's Avatar
why? it's 346 cubic inches with a big bore, that'll make a lot of torque, you just need to gear/stall the car so you're in the powerband
Old Sep 4, 2006 | 01:41 AM
Wnts2Go10O's Avatar
that and the destroked 377's (originally 400cid) produce some good torque.
Old Sep 5, 2006 | 10:43 AM
jerflash's Avatar
coolest small block is the 350 made from a 400 block and a 283 crank which is what this sounds like haha
i would love to have a high revvin small block...over 8K would be awesome
Old Sep 5, 2006 | 12:18 PM
zigroid's Avatar
you talking about this:
http://purplesagetradingpost.com/sum...%20engine.html
Old Sep 5, 2006 | 01:26 PM
Wnts2Go10O's Avatar
Originally Posted by zigroid
talk about stump puller..
Old Sep 5, 2006 | 01:38 PM
jerflash's Avatar
ya thats what im talkin about
speedomotive makes a shortblock also
Old Sep 8, 2006 | 09:17 AM
NO-OPTION-2002's Avatar
400 bore = 4.125"
283 stoke = 3.000"
That is 320.7ci, not quite a 350.
Old Sep 8, 2006 | 04:04 PM
SS_bnoon_SS's Avatar
Originally Posted by NO-OPTION-2002
400 bore = 4.125"
283 stoke = 3.000"
I thought they used the 327 crank, not the 283... that's 3.25" stroke...
Old Sep 8, 2006 | 06:01 PM
Ahh, now that would be a 350. 347.5ci is close enough to count.
Old Sep 8, 2006 | 06:23 PM
firefighter's Avatar
Thats what I've been thinking about doin. Take a 3.625" stock crank with a 4.19" bore sleeved/LS2 and get just shy of 400ci with long 6.2" rods you get an incredible rod ratio and at least from Dynosim you get some really good numbers.
