Katech Value 427 dyno test - 3 cams
Old Oct 9, 2006 | 09:09 AM
SideStep's Avatar
*BUMP*... for some reason this did not come to the top after previous post...
Old Oct 9, 2006 | 09:15 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by 11 Bravo
That stage 3 cam looks real nice, lower torque would actually be a good thing for my tires, but I think it would be too radical for the street.
Yes, I wouldn't recommend the stage 3 for a street car.
Old Oct 9, 2006 | 09:18 AM
LS1TECH Sponsor
Originally Posted by SideStep
I want to resurrect this thread and ask how much advance (if any) this cam has...
All cams were installed straight up.
Old Oct 10, 2006 | 05:24 PM
AU N EGL's Avatar
Of the three this would be my choice
Katech Stage III "Trac" cam for my use
Old Oct 13, 2006 | 07:35 AM
SideStep's Avatar
Thanks...
Old Oct 13, 2006 | 07:49 AM
vmax1500's Avatar
I agree... it looks alot like the cam in my 427
It would be very interesting to see what sort of an increase there would be by swapping to LS7 heads and intake... I would guess 50HP... Jason, what do you think?
Old Oct 13, 2006 | 09:29 AM
LS1TECH Sponsor
Swapping to the LS7 heads, intake, and our LS7 cam should be identical to our Street Attack LS7 at 608hp. A recent chassis dyno of a LS6 7.0L w/ LS7 top end, and LS7 Torquer camshaft confirmed that within 4hp of our Street Attack package.
Old Oct 13, 2006 | 09:57 AM
Quickin's Avatar
You only get 12 more hp going with LS7 heads and LS7 intake over your Stage III with LS6 heads and LS6 intake????
Test 2: (C4-3481 - blue) Katech Stage III "Trac" cam
- 258/258 @ .050 .578/.578 lift, 110 LSA
- 594hp, 543 lb-ft of torque
What am I missing????
Old Oct 13, 2006 | 10:04 AM
LS1TECH Sponsor
I'm talking between 2 streetable cams, the K.spec, and the Torquer LS7. The Trac cam is not a street cam.
Old Oct 13, 2006 | 10:59 AM
vmax1500's Avatar
Could you post a dyno comparison?
Old Oct 13, 2006 | 11:32 AM
LS1TECH Sponsor
Old Oct 14, 2006 | 05:07 AM
  #32
Bring the Noise's Avatar
Any idea what the LS7 Torque cam would produce if the top half was an unported L92 with L76 manifold setup (on that 427 of course)?
Old Oct 14, 2006 | 08:12 AM
  #33
MeentSS02's Avatar
Kleeborp the Moderator™
Would you be willing to divulge the ramp rates of the cams? Comp XE-ish, XE-R-ish?
Old Oct 14, 2006 | 05:51 PM
  #34
LS1TECH Sponsor
Nope
_
  #35
LS1TECH Sponsor
XE-R
Old Oct 15, 2006 | 09:07 AM
  #36
MeentSS02's Avatar
Thanks Jason!
Old Oct 16, 2006 | 06:59 AM
  #37
SideStep's Avatar
XE-R
XE-R
But the lifts you show look closer to XE lifts...??? What rocker-ratio are you using on these setups???
Test 1: (C4-3470 - red) Katech Stage I "Torquer LS6" cam
- 204/218 @ .050, .551/.551 lift, 112 LSA
- 516hp, 558 lb-ft of torque
Test 3: (C4-3487 - black) Katech Stage II "K.spec" cam
- 229/229 @ .050 .576/.576 lift 116 LSA
- 552hp, 549 lb-ft of torque
Old Oct 16, 2006 | 07:22 AM
  #38
AU N EGL's Avatar
I dont think Jason and Katech will give all their secrets out.
It seems to me that Katech has been very successful high engine outputs with relatively conservative numbers.
Old Oct 17, 2006 | 12:19 AM
  #39
SSDude's Avatar
Your numbers are strong. What are the specs on the LS7 cam and have you tested it in this set up?
Old Oct 17, 2006 | 08:01 AM
  #40
LS1TECH Sponsor
https://ls1tech.com/forums/showthrea...s7+torquer+cam
Not in a Value 427 yet. Only tested in an LS7.
