C5 and C6 transmission mounted behind driveshaft???
Gingervitis Addict ![](http://s24.postimg.org/5ong4sl1t/Gingervitis2.jpg)
Originally Posted by c5racr1
it is not 1 unit, the t56 trans is BOLTED to the getrag diff, to independent units, they do not share fluid. the output shaft of the t56 is splined to the ring gear of the getrag diff. not even close to a transaxle. a FWD car is a transaxle.
I know they are bolted together, I was just saying that there is no driveshaft between them.
Here is a quote from the www.chevrolet.com
Because the transmission is located in the rear of the car and is connected to the engine by means of a transaxle and torque tube, Corvette achieves a near 50/50 weight distribution for better overall performance.
Being a C5 Corvette owner I have always found it interesting to observe how GM engineered the car when it's on the rack. My car is an A4. If you removed my trans and placed the correct bell housing and tailshaft on it you could bolt it into your f-Body.
With the A4 Corvette the flex plate and torque converter are mounted at the rear of the car in front of the A4. A pilot shaft is splined into an aditional flex plate with the ring gear for the starter on the engine. Those splines are then clamped against the pilot shaft. The drive shaft runs down the center of the torque tube with bearings on each end and a flexible joint. However, this setup allows the drive shaft to whip at higher RPMs which tends to wear the flex joints.
Some guys running higher HP cars have replaced the shaft with a carbon fibre unit and solid flex joints from LG Motorsports.
It's a really clever design and you will note that there is no trans mount like you see in the F-Body. The torque tube bridges the gap between the rear of the engine and the front of the trans. This is what holds the rear of the engine up.
aston martin and ferrari use the same setup on the DB9 and 599 etc etc. i dont know if they run the tubes over the shaft or not.
why do the vets have the half shafts encased aswell???? its not done on other makes!
thanks Chris.
thanks Chris.
thanks Chris.
thanks Chris.
The inner cylinder is solid with three U shaped channels milled laterally along its outside walls. The outer cylinder, which is hollow, has three U shaped channels milled laterally along its inside walls. Put one cylinder inside the other so that the U shaped channels of each match up and you get what amounts to 3 bored tunnels passing through the joint parallel with the shaft.
When these two units come together they insert large ball bearings into the channels and pack in lots of grease. The result is an infinately flexible joint that not only moves through a complete arc but can move in and out as well. GM probably didn't invent it but it's pretty clever engineering.
LeMansBlue04, are you discribing to me a CV joint???
lol
i know what one is and they are used all the time over here (uk) and have been for years. i dont think there are any cars (and few SUVs!!) that use axels anymore over here.
so they are just dust covers????
at what point do you start to have to think aboutusing a solid axel then?? i mean with moders machineing and alloys you can make some DAM strong diff casings and equally strong half stafts! whats the advantage of a axel?
thanks Chris.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
thanks Chris.
lol
thanks Chris.
thanks Chris.
A solid rear axle doesn't cause so much geometry changes to the rear tires when placed under those same enormous loads. It doesn't mean an IRS can't be used, it's just a much bigger challenge getting the suspension dialed in, and keeping it dialed in. Some people prefer that challenge.
jRaskell, thats strange cos they say that IRS is much better for racing than solid axels!?!?!?!? why is it so hard to get things diled in?? and what is the movment that gives the IRS so much trobule??
thanks Chris.
thanks Chris.
thanks Chris.
thanks Chris.
IRS gets put on vettes for a smoother ride, their owners expect a better ride for the extra money they put down. A live axle can be designed in with more anti-squat than an IRS. Cars that have an emphasis on drag racing will go with a live axle. That's why f-bodies, which need to post solid numbers in the 1/4 and 0-60's and be cheap, use a solid axle (and a torque arm for good measure). Vettes get the IRS for comfort because of the extra money and they will post solid numbers because of the bigger tires/more power/lighter weight advantage. As an aside, I'm not sure which current Mustangs use solid axles. Frankly, I don't care. But I'm 99% sure that the Shelby GT500 with 500 hp uses a solid axle and the reason the Stangs use solid rears is for cost and to dial in anti-squat. You'll need all you can get on a 4000 lb 'sports car' because it needs every bit of help at launch and immediately afterwards to get some grip to haul it's fat a** around.
#32
so the main advantage is in anti squat?? is it not easier to make a axel take BIIIGGGG power than an IRS???
i still like IRS, but thats just cos i have grown up with it over here. but i do see the advantages it would brinmg to a street car used manly for the 1/4mile!
OH and they can be very fun in a sharp handling car with more power than grip! try driving a Mk 1 or 2 ford Esscort and you will see what i mean!!!![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
thanks Chris.
thanks Chris.
#33
Originally Posted by See5
I think what make it interesting is that the drivsehaft spins at engine rpm. So it can spin @7,000 rather than trans output revs. It takes rubber insulators and driveshaft in a tube to pull this off.
Think about what a standard driveshaft goes through....7000rpm isn't all that ridiculous....If you've got a T56 6 speed with the .5:1 6th gear, and you're turning 3500 rpm (engine rpm) what speed is the driveshaft running? You guessed it, 7,000 rpm.
Those roundy roundy Nascar guys run conventional driveshafts (although they're probably made out of unobtanium for weight reduction) and they spin them hard, like 9,500+ rpm
I'm not saying that every driveshaft can do the deed, just trying to point out that with today's overdrive transmissions, a plain old driveshaft is required to run "silly" rpm (a fact that is often overlooked). And that the torque tube design isn't necessarily required. To meet GM's requirements I'm sure it was (otherwise they wouldn't have done it), but not everybody agrees with their requirements (I'd personally like to be able to buy a front engine / rear drive 2000 lb 2 seater with an 800hp v8 from GM for $25k or less, but I don't think that my requirements agree with their desire to make money).
'JustDreamin'
#34
Guys, you have gotten way off track here. The reason the Vette has an IRS is because it handles better than a solid axle. One tire can move without effecting the other. The F-Body has a solid axle because it cost less to build.
This fact is one of the key reasons a Corvette handles better than an F-body or a Stang.
And.... as any Corvette owners wife can tell you, there is nothing smooth about the ride of a Corvette. The run flat tires make it even worse.
#36
Originally Posted by SSCamaro99_3
Steel, as per the rulebook.
Has they always been steel, or were the rules changed when the rear gear rules were put in place?
I could have sworn they were running some exotic materials a few years back.
Still way off topic from the original poster's question, however.
'JustDreamin'
