another ls7 rocker failure
Old Sep 11, 2006 | 02:04 PM
vtanju's Avatar
Originally Posted by Greg Fell
are you using a lash cap? the ti intake valves are not hardened, and will wear out very quick. you MUST use a lash cap.
thanks alot buddy, i did not know this. almost destroyed another set, guess i can buy the lash caps from GM right.
thanks again
Old Sep 11, 2006 | 02:07 PM
LeMansBlue04's Avatar
Originally Posted by vtanju
hi guys,
the problem i had was that the tip titanium of the intake valves where the rockers are in contact wear out, and i mean wear out fast like in 2 hours of operation. exhaust is fine. any ideas.
Carefully check your valve train geometry. I saw a recent case where AFR had a customer who set up his valve train incorrectly. His pushrods were to long resulting in only half or 1/3 of the valve stem working against the rocker arm pad. Most of the contact was on the outer edge of the valve stem. This caused excessive pressure and wear in one spot. It quickly wore through the hardened surface of the SS valve stem. After you penetrate the hardened surface a valve wears very quickly.
Ah, there's the answer in the post above. I was wondering how a Ti valve can be hardened.
Old Sep 11, 2006 | 02:14 PM
Greg Fell's Avatar
yes, and you can order custom thickness ones from vacmotorsports...ask for chris. i recommend using custom ones to get your valvetrain geometry dead nuts on
www.vacmotorsports.com
Old Sep 11, 2006 | 02:26 PM
Nasty N8's Avatar
Yes Haland Sharps mod works for the LS7 rockers as well we have done a few sets already.
Give me a call we will set you up.
Nate
