Patriot LS6 Stg III heads with big cam
There are larger cams such as the TSP MS4 or LGM G5X3 cam that work with the stock heads, but will require flycutting with milled heads. I was just wondering if the MS4 or G5X3 (more the X3) would work with these specific heads without any work needing to be done to the pistons.
Thanks folks.
Thanks folks.
Originally Posted by Blown04Z06
call LG
if i remember correctly the X3 doesn't require fly cutting, i inquired about that cam last year. the X4, X5 does
on a stage 3 head with a big valve, you are gonna have some trouble.
