Got My Ls7 Carbed Intake Today
Old Sep 27, 2006 | 11:41 AM
matt346ls1's Avatar
Default Got My Ls7 Carbed Intake Today
It looks promising so far to mate up with my C5R heads. I will be doing some mock up later and making sure. Intake walls are thin so porting it is going to be kept to a minimum. I will post some pics later if I can.
Matt
Old Sep 27, 2006 | 11:59 AM
SlickVert's Avatar
How long are the runners?
Bob
Old Sep 27, 2006 | 12:02 PM
matt346ls1's Avatar
They look a little longer than the LS1 carbed intake but not much. Maybe an inch.
Old Sep 27, 2006 | 12:35 PM
Hennytime's Avatar
pic or ban
Old Sep 27, 2006 | 01:09 PM
matt346ls1's Avatar
Originally Posted by Hennytime
pic or ban
OK OK
Attached Thumbnails Got My Ls7 Carbed Intake Today-intake2.jpg   Got My Ls7 Carbed Intake Today-intake.jpg
Old Sep 28, 2006 | 07:04 AM
matt346ls1's Avatar
pics of intake on c5r heads. The lip on the c5r head would have to be machined off. Other than that the intake will need some major modifying but I think is the best start to have. I also mocked up an sb2.2 intake and had similar results.
Attached Thumbnails Got My Ls7 Carbed Intake Today-intake3.jpg   Got My Ls7 Carbed Intake Today-intake4.jpg   Got My Ls7 Carbed Intake Today-intake5.jpg
Old Sep 28, 2006 | 11:06 AM
Classic's Avatar
Looks like the manifold ports are considerably larger than your C5R ports???? Still looks like a decent starting point.
Is the LS7 manifold taller than the LS1/6/2 version?
Old Sep 28, 2006 | 11:09 AM
matt346ls1's Avatar
They are....... But as soon as we play with the heads they won't be.
I think it is taller, but not by a ton. I wish it was like an sb2.2 heigth wise.
Matt
Old Sep 28, 2006 | 02:45 PM
SStrokerAce's Avatar
Mill the intake not the heads to make it fit, works out better that way.
I have a set of C5R heads that have been waiting for this intake for a while now!
Bret
Old Sep 28, 2006 | 03:23 PM
matt346ls1's Avatar
Personally except for the injector bosses I don't see it being as good as the SB2.2 intake. Not enough runner volume and the 4 inside runners are 3 inches and the 4 outside are like 6". GM needs to stop trying to make things fit under low hoods and make an all out performance manifold.
Matt
Old Sep 28, 2006 | 08:44 PM
brodix1's Avatar
whats the part number for the intake i have some c5r heads myself looking for intake thanks
Old Sep 28, 2006 | 09:51 PM
Matt
That's what weld is for!!!!
Old Oct 2, 2006 | 02:07 PM
Tuf-Titan's Avatar
From whom did you buy this intake and for how much? Thanks.
Old Oct 2, 2006 | 07:14 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
It's GMPP # 25524401 I think. I tried it a month or so ago and it came up on the gmpp website, but now it doesn't. Your best bet is SDPC.
You should be able to order it through SDPC ---------------->
They're a sponsor.
https://ls1tech.com/forums/showthrea...light=LS7+carb
That's a link to the release of it.
Old Oct 2, 2006 | 07:42 PM
TopFlite's Avatar
Nice stuff you got there. What size carb will you use with your application?
Old Oct 3, 2006 | 12:19 AM
Tuf-Titan's Avatar
Thanks bud.
Old Oct 3, 2006 | 06:07 AM
matt346ls1's Avatar
I ordered it through the Cadillac dealer across the street from where I work. I got a good deal it was $335 plus tax. It took 4 days to get it. I am using a wilson 4 barrel throttle body on top. 1388cfm.
Old Oct 4, 2006 | 12:28 AM
Tuf-Titan's Avatar
whats the part # i need one of these bad boys ASAP.
Old Oct 4, 2006 | 03:58 PM
ArrestMeRed99Z28's Avatar
Looks like an awsome set up, apparently matt can not be satisfied with a 9 second all motor car, love to see a video of your first trip to the drag strip with this setup. What is your prejected ET and MPH with the new intake?
AJ
Old Oct 4, 2006 | 07:38 PM
matt346ls1's Avatar
AJ
I am hoping to go 8.7x @ 155+. realistically I just want an 8 sec slip.
Matt
