Blue Devil Powertrain....
Here are my thoughts:
-Aluminum 6.2L block
-Dual Camshaft in block / Variable valve timing
-3V / Cylinder
-Dual spark plugs per cylinder
-Forged Slugs / Rods / Crankshaft
-Twinscrew style blower (similar to the Ford GT unit) with 10-12PSI of boost.
Rationale:
-6.2L block - to increase cylinder wall thickness (over current LS7/C5R blocks), and decrease stroke to cope with the increased cylinder pressures of forced induction.
-Dual camshaft in block (pushrod) - Because they can, and have submitted approval for a patent on this configuration. I personally dont see an advantage to this configuration over SOHC, but there are some implications behind cam phasers/ variable valve timing / with this configuration that I dont fully understand.
-Dual Spark plugs per cylinder- This makes for a tidy combustion chamber that should have some killer combustion/ swirl properties.
-Forced Induction - Because for some reason the torque characteristics of the more-than-two valved heads never seem to be able to duplicate the old school heads. Compare the torque curve on a dyno graph from a naturally aspirated '01 4V cobra motor to the roots blown '03 graph....The torque curve gets completely flat, and you gain 100ftlbs at 2200 RPM.
-Forged internals - Its required for forced induction - but really - Because GM is begging for you to put a smaller pulley in this beast, run 21lbs of boost, and rape your friendly Ferrari pimping neighbor
.What do you all think?
It is amazing how it has become such a myth!
-Geoff
. You know, the more I think about it (reality check), I am not sure that the higher valvetrain mass of the 3V setups will work out in a high RPM application like the Uber-Vette, but it is nice to speculate.
-Geoff
From what I understand the current prototype is a LS2 with a roots blower sitting on top. Lots of names like Corvette SS, Bluedevil, Stingray,... have been kicked around. Who knows what it will be called when/if it makes production.
i would also bet that IF they ever released the motor as a crate, id bet it would cost about the same as a ls7, and would drive the ls7 price down to about 11,000 dollars. just speculation, but my $.02
i also forsee alot of accidents and high speed deaths, even more so than that of the current c6z's mortality rate
I also read that the LS9 would be a 6.0L V8 DI (Direct Injection) DOHC motor supercharged, but that info looks like BS or just a motor GM was experimenting with and not for actual production use.
There is an interesting 3.6L V6 VVT DI DOHC motor GM announced back in May that is going to be used in alot of V-6 vehicles at the end of 2008(probably a base Camaro).
