LS2 RPM Capability
6800 is likely as far as you want to push the stock rods.... if you went with some superior aftermarket rods, then knock yourself out....
others will chime in I am sure.. but unless you like buying new engines, 6800 is probably getting you where you want to go....
Ben T.
I have Katech rod bolts (2000 c5 LS1)and the car makes max power at 6600 so I tried 6800 because it is an A4.
NOTHING GAINED,so I lowered it to 6600 same ET REV LIMIT IS SET AT 7000
AFR 205's, LS6 intake, ported TB, ported LS6 oil pump, LS2 Tchain, Longtube headers as upgrades.
I'm running a TSP 233/239 .600/.603" 112LSA cam in my motor. Pulls very hard up to redline. I'm sure with a FAST90 intake it would be even better.
Yes you are pushing it going to 7K.... but with a good tune, upgraded rod bolts and one not seeing that kind of RPM for very long..... you should be fine. I only rev it like this when drag racing. On the street and road racing I keep my shift points at around 6600rpm and if I have to pass someone I will spin it higher.
My car MPH's the highest when I spin it up there at the 1320.
