How much power out of this LS2 418cid?
Old Oct 1, 2006 | 07:49 PM
Randy WS6's Avatar
Default How much power out of this LS2 418cid?
What kind of power should i get out of the aluminum LS2 418cid.
Mods. Custom made ROSS 4.030" flat top pistons with 6cc valve reliefs, forged Eagle 4.100" crank,Eagle 6.125" rods with L19 ARP rod bolts,Crane Hydraulic roller 650/650-250/266-112 +2 ,Comp Pro Mag.1.75" roller rockers, TSP cnc (Dart Pro1) 255cc intake runners, 2.100" intake valves,1.60" exhaust valves 59cc polished chambers,Fast 90 match ported to heads ,Holley 90mm TB, ARP head/main studs,LS2 double roller timming chain,Ported LS6 oil pump,Meziere electric water pump, and a little nitrous later ,6speed , aluminum flywheel,SPEC stage 3+clutch,ford 8.8 31spline moser axles, 4:30 gears. Motor going in next weekend, if i dont haft to work !!
more pics here
<embed type="application/x-shockwave-flash" wmode="transparent" src="http://w6.photobucket.com/pbwidget.s...1159758980.pbw" height="240" width="360"></embed>
My car here
<embed type="application/x-shockwave-flash" wmode="transparent" src="http://w6.photobucket.com/pbwidget.s...1159758859.pbw" height="240" width="360"></embed>
action=view&current=1159758980.pbw
Old Oct 1, 2006 | 08:00 PM
Wnts2Go10O's Avatar
ummm... 550 na, 1000 si, give or take 200hp=)
Old Oct 1, 2006 | 08:18 PM
Quickin's Avatar
Originally Posted by Wnts2Go10O
ummm... 550 na
FWHP
WTF does si mean?
Old Oct 1, 2006 | 11:13 PM
Adnectere's Avatar
It means that all the chrome will dazzle them into submission. Beauty.
Old Oct 1, 2006 | 11:19 PM
Wnts2Go10O's Avatar
Originally Posted by Quickin
FWHP
WTF does si mean?
nope, at the wheels. si is spray induction as in nitrous.
Old Oct 1, 2006 | 11:25 PM
THE_SUPRA's Avatar
i dk about the power but sheeiit! that is good lookin, is it goin in the ws6?
Old Oct 2, 2006 | 12:11 AM
Quickin's Avatar
550 RWHP? That'd be cool. Whats the compression? Do you know what those heads flow?
Old Oct 2, 2006 | 12:57 AM
Rob98LS1's Avatar
What kind of exhuast is this engine going to be hooked up to?
Old Oct 2, 2006 | 06:27 AM
Randy WS6's Avatar
It's going in my WS6, and The compression 12.5.1 and the heads flow 346cfm @ .650 . The exhaust i have long tubs with duel cut outs after the collector. with after (Y) pipe 3" with a Hooker Aero Chamber muffler. And there is no chrome on the motor its all aluminum.
Old Oct 2, 2006 | 09:40 AM
SlickVert's Avatar
I would guess north of 550rwhp in a M6 car.
Biggest bottle neck is the Fast 90 intake, get a custom sheet metal and you could gain 30hp or more.
Bob
Old Oct 2, 2006 | 10:38 AM
Randy WS6's Avatar
Do they make a sheet metal intake to fit under the F-Body hoods and under the wind shield area. I can build one if i had a (picture), I made my own valve cover for this engine.
Old Oct 2, 2006 | 10:56 AM
SlickVert's Avatar
John Beck does.
He is on your sponsor list
Bob
Old Oct 2, 2006 | 06:17 PM
slow trap's Avatar
on a dynojet i'll say 553 rwhp,518 rwtq.
Old Oct 2, 2006 | 06:31 PM
pdd's Avatar
pdd
very nice
Old Oct 2, 2006 | 07:43 PM
Randy WS6's Avatar
Thanks, So around 550 to 560 on the hp, Good power on the street, So what a bout at the crankshaft hp?
Old Oct 2, 2006 | 08:28 PM
KAOS's Avatar
if you didnt get 550 rwhp i would be upset. that 402 with the tfs heads put down 550 and i bet they dont flow like that. with a carb style intake i would expect a gain over the fast setup. but i dont think 550 is goin to be a problem
Old Oct 3, 2006 | 06:35 PM
rwb's Avatar
rwb
With 12.5 to 1 compression you should be way above 600hp. Just keep it out of detonation.
Old Oct 3, 2006 | 07:08 PM
Randy WS6's Avatar
I have upgraded to the Commercial EFI Live tuner and will try to tune in SD mode and im going to order a wide band in a few days.
Old Oct 4, 2006 | 08:55 PM
Randy WS6's Avatar
ttt.......
Old Oct 4, 2006 | 10:51 PM
SSilverSSurfer's Avatar
good luck, that sounds like it should be a monster, make sure to get some vids
