View Poll Results: What is the biggest stroke that will fit a stock LS2 block
Voters: 93. You may not vote on this poll
4.1" or 4.125" stroke possible in a stock LS2 block?
Originally Posted by Dragaholic
So the only cranks that Eagle makes is 4.00" and 4.100"? That's a pretty narrow selection. What about Callies? Any difference in quality? I know Callies is more expensive, wasn't sure if its just the name.
I thought it had .065" more bore? What's DOD?
9 Second Club NA
I know 4" is a pretty popular crank size. I figured 4.100", 4.125", and 4.250 were too. So what makes Callies better than Eagle? Those 2 are the brands I'm considering as I can't afford Lunati. I have yet to decide, so I'd like to know.
I'll double check/search and see what the bore is. I could of swore I read 4.065".
Could you elaborate more on displacement on demand? Still means nothing to me. Thanks.
DOD is an oil pressure activated, deactivation of lifters, that effectively turns the v8 into a 4 cylinder engine resulting in a 7% increase in fuel economy.
Does anyone know what extra work needs to be done when not using DOD in a shortblock build up?
Not trying to drum up business here, but email me at bnutter@wiseco.com I'll help if I can, because it's definitely not up to a "vote". -Brian Nutter
Originally Posted by Blown04Z06
ill be looking forward to seeing your results to see if my thought process is correct or not. the 418/422 combo should break into the 525/525 with out running a huge cam or building a max effort motor.
So I sure hope builders can get 525/525 today from a 422.
OWN3D BY MY PROF!
Originally Posted by GIGAPUNK
I've never heard mention of any differences in the depth of the sleeves in the L92. The deck ht is the same as the LS2, it just has a .060" bigger bore and DOD.
#32
I'm in the middle of reading all 14 pages of the SDPC L92 thread. First BG-SDPC says straight out that 4.1 is out of the question b/c the liners are too short. A page later he states that the liners are exactly as deep as those on the LS2, and that it is a piston ring placement issue.
#34
Sled, where can I get a good deal on those 6.2" rods?
Cost? What brand do you use?
#35
Eagle just started selling a 4.25" stroke crank that they made specifically for the Warhawk blocks. I know that the rod/stroke ratio would be bad, but does anybody think that one of these would fit in a LS2/L92?
Stroked LS1 4.25":
4.25*1.5=6.375
4.25/2=2.125
9.245-2.125= 7.12-1.339= 5.781 rod needed to use stock pistons CH
7.12-6.200 rod= 0.920 CH
7.12-6.125 rod= 0.995 CH
7.12-6.1 rod= 1.02 CH
7.12-6.0 rod= 1.12 CH
RSR 6.200/4.25 = 1.458
RSR 6.125/4.25 = 1.44
RSR 6.100/4.25 = 1.435
RSR 6.000/4.25 = 1.41
Stroked LS1 4.25":
4.25*1.5=6.375
4.25/2=2.125
#37
Stroked LS1 4.25":
4.25*1.5=6.375
4.25/2=2.125
Stroked LS1 4.25":
4.25*1.5=6.375
4.25/2=2.125
#38
Nate
#40
9 Second Club NA
What the heck is up with this thread? I keep seeing it get bumped up with new postings, but when I view the thread, it still has the same last post from Randy WS6. If you're looking at the threads just browsing the section, you'll see the last post was made at 10:41 pm yesterday, but when you actually go into the thread and view it, it says the last post was made on 10/27/06.
