.030 gaskets w/ l92s on lq4
Old Oct 7, 2006 | 05:30 PM
Wnts2Go10O's Avatar
Default .030 gaskets w/ l92s on lq4
anyone think ill have clearance issues? im gonna double check bu twhat do you think?
Old Oct 7, 2006 | 05:56 PM
WKMCD's Avatar
Old Oct 7, 2006 | 06:21 PM
Nate_Taufer's Avatar
I personally wouldn't go any thinner than .040" Once you start getting closer you are begging to kiss a valve. Plus with a 2.16" intake valve PTV is going to be close.
Nate
Old Oct 7, 2006 | 06:58 PM
Wnts2Go10O's Avatar
well it is a dished piston so i would think itd be alright but im not 100% sure so im asking.
Old Oct 7, 2006 | 08:03 PM
WKMCD's Avatar
How many cc dish?
Old Oct 7, 2006 | 09:06 PM
Wnts2Go10O's Avatar
its a stock lq4 short
Old Oct 7, 2006 | 09:57 PM
garrettpen's Avatar
Are you trying to get the compression up, or why such a thin gasket? if so why not just deck the head and go with a normal thickness gasket?
Old Oct 7, 2006 | 11:09 PM
Wnts2Go10O's Avatar
well this was my thinking: since i wnt to go fi later i wnt to leave the heads alone but i also wnt a bit more compression in the sake of power and i can always change the gasket later to lower comprsion but cant put metal back on the deck.
