Wanting to know the engine build codes.
Old Oct 8, 2006 | 02:12 AM
tylerdurden's Avatar
Question Wanting to know the engine build codes.
I tried the search but no luck. I wanted to get schooled on engine build codes like the L76 L92 etc. etc. Is there a site to find out the exact mearsurement and so fourth and what is interchangable. For example I have read that you can put differant intakes but they dont work well with all the cylinder heads.
Thanks for any inputs in advance.
Old Oct 8, 2006 | 02:59 AM
Stang's Bane's Avatar
Read the stickies in here and the LS1/LS6 section, that will def. get you started.
Old Oct 11, 2006 | 07:51 AM
Talking
Well this is what I found out.
Engine Displacement Power
LY2 4.8L 305hp
LC9 5.3L 310hp
LY5 5.3L 345hp
LMG 5.3L 345hp
LY6 6.0L 369hp
L76 6.0L 355hp
L92 6.2L 403hp
Are all these engine blocks aluminum and based off the ls2 block spec. with the exception of bore and stroke?
Old Oct 11, 2006 | 09:52 AM
12secSS's Avatar
Go directly to the horses mouth.
http://media.gm.com/
