Lsx engine builders
Old Oct 8, 2006 | 03:50 AM
ss dave's Avatar
Default Lsx engine builders
I have a 69 Camaro with a carbed 383 that I would like to swap to a FI Lsx specifically a Ls2 or Ls7. I'm not a engine builder therefore I'm lookig for a quality professional builder that maybe you guys have had some experience with. I would like a streetable 525-550HP motor. I done a search and SDPC and W2W are a few mentioned. I would like a Turn key type set up. Any experience with Turn Key Eninges in Oceanside, Ca? They have a 550hp ls2 that is reasonable. Thanks for any help.
Old Oct 8, 2006 | 05:22 AM
Stang's Bane's Avatar
There was a thread on here a while back about Turn-key not delivering on their horsepower quotes. Personally I would look at a LS2 402 shortblock from one of the sponsors and top it off according to your budget and/or wishes. I know SDPC had a very good deal on one that they had, check the "for salel "section. Spearatech has wiring harnesses for almost everything and they are pretty reasonable. hope this helps.
Old Oct 8, 2006 | 10:19 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Take a look at our packages. You may be interested in a Street Attack LS7 or Value 427.
http://www.katechengines.com/street_...e_packages.php
Old Oct 8, 2006 | 11:02 AM
ss dave's Avatar
Thanks, I thought the 510 HP Turn Key LS2 looked to good to be true, it appeared to be a stock LS2 with just a different chip/ tune added, maybe I'm wrong. Jason on another thread you posted the cost of the Street Attack LS7 as a price + LS7. 'm not sure what that means, is it price + LS7 block? That set-up although as sweet as it is maybe to much HP (630+) wow! I have a vert with 275 Nittos in the rear and would probably do fine with a 550HP engine and even then that may be too aggressive for a street car. However I'm open to any suggestions. Thanks
Dave
Old Oct 8, 2006 | 11:27 AM
SSZ's Avatar
SSZ
http://www.cdnperf.com/. Builders name is Dave DiLuca. Great guy and honest. Builds lots of killer LSx engines. Good prices too
Old Oct 8, 2006 | 01:14 PM
LS1TECH Sponsor
Dave
Price plus LS7 crate engine. You may like our Value 427 with K.spec cam and Stage III LS6 heads at 552hp/548tq.
Old Oct 8, 2006 | 08:24 PM
ss dave's Avatar
Jason, great numbers, lots of tq. It has to have street manners. What kind of performance do you have in an 402? I have heard of Dave DiLuca in a mag. article, it was a nice ride and the owner was pleased with the performance.
Old Oct 9, 2006 | 05:45 AM
ss dave's Avatar
Jason, I checked your website and found a few other interesting blocks thay may work for me, the Torquer, and Storker LS2 and the Kspec 408. For comparison do you have any combo numbers for those blocks in the range of HP that I'm looking for? I believe that the April Hot Rod mag did an article on Katech taking a stock LS2 and achieveing close to 500hp with bolt on parts I didn't see the article but would appreciate any info on the details. Thanks
Dave
Old Oct 9, 2006 | 07:16 AM
Reckless's Avatar
Super Moderator
We could certainly handle anything you need. Most of our "turn key" engine options are found here:
http://www.w2wpowertrain.com/c-80-turn-key-engines.aspx
Old Oct 9, 2006 | 07:42 AM
LS1TECH Sponsor
The K.spec cam has excellent street manners. It's on a 116 LSA.
Here is the hot rod article.
http://www.hotrod.com/techarticles/1...ild/index.html
For the price of this 427, a 402 just doesn't seem worth it anymore.
Old Oct 9, 2006 | 07:46 AM
LS1TECH Sponsor
Dave
I have a K.spec 408 in stock ready to ship 525hp. Same engine that was in the K.spec CTS-V we did a while back. Asking $20,000 obo.
# GM Performance Parts C5R block
# ARP Main studs
# Callies Crankshaft
# Carrillo connecting rods
# Ported and blueprinted oil pump
# Katech pistons
# Mahle rings
# ATI Dampener
# CNC Ported LS6 Cylinder heads
# 2.100" Lightweight intake valves
# 1.550" Lightweight exhaust valves
# Katech K.spec camshaft
# LS6 Springs
# Returnless fuel rail
# CNC ported throttle body
# 160 Deg. Thermostat
# 38# Injectors
# Katech cast aluminum valvecovers with blue powdercoat
# Katech coil relocation brackets
# Katech billet belt tensioner
# Equipped with CTS-V oil pan
Old Oct 9, 2006 | 08:07 AM
ss dave's Avatar
Nice set-up and I'm sure its a quality product, however since I'm swapping carbed power for FI in a 69 I have other considerations for the conversion and would like to keep the entire budget less than 20K. I agree with you on 427 v. less ci. and I'm leaning in that direction. By the way both Katech and W2W were recommended by some knowledgeable people on another site so I'm glad for the input.
